Fault Codes - help
Fault Codes - help
Please could someone explain what these fault codes mean(car is Audi Q5).
Address 01: Engine (J623-CCWA) Labels: 059-907-401-CAP.clb
Part No SW: 8R0 907 401 J HW: 8K1 907 401 A
Component: 3.0TDI EDC17 H01 0008
Revision: 15H01---
Coding: 0121002C240F0928
Shop #: WSC 00121 210 86201
ASAM Dataset: EV_ECM30TDI0118R0907401J 001008
ROD: EV_ECM30TDI0118R0907401J.rod
VCID: 397326D2B842B31
4 Faults Found:
4807 - EGR System
P0401 00 [096] - Insufficient Flow
Intermittent - Not Confirmed - Tested Since Memory Clear
7140 - Function Restriction due to Received Malfunction Value
U1113 00 [032] - -
4528 - Coolant Fan Control Circuit 2
P0481 00 [047] - Electrical Malfunction
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 91450 km
Date: 2011.05.21
Time: 11:09:03
18660 - Unknown Error Code
P151D 00 [032] - -
Readiness: 0 0 0 0 0
Next Fault Code:
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 Q HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0095
Revision: FB600048 Serial number: 4800F091158229
Coding: 000303
Shop #: WSC 06335 000 00000
VCID: 4FA7780A1EC60D1
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 60
Mileage: 119292 km
Time Indication: 0
Date: 2012.06.30
Time: 18:18:00
Next fault code:
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T2 035 670 D HW: 8T2 035 670
Component: H-BNT-EU H64 0047
Revision: -------- Serial number: 329AS097514093
Coding: 01010106010581EF01002B1E000000030000
VCID: 377720EA8656A51
Subsystem 1 - Part No: 8R0 060 884 C
Component: EUROPE 2008 5608
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
1 Fault Found:
01043 - Control Module; Incorrect Software Version
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 17
Mileage: 91450 km
Time Indication: 0
Date: 2011.05.21
Time: 11:09:32
Freeze Frame:
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00010000
Next fault code:
Many thanks Mark
Revision: 15H01---
4 Faults Found:
4807 - EGR System
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 91450 km
Date: 2011.05.21
Time: 11:09:03
P151D 00 [032] - -
Next Fault Code:
Coding: 000303
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 60
Mileage: 119292 km
Time Indication: 0
Date: 2012.06.30
Time: 18:18:00
Next fault code:
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 17
Mileage: 91450 km
Time Indication: 0
Date: 2011.05.21
Time: 11:09:32
Freeze Frame:
Next fault code:
Many thanks Mark
