VAG-COM Discussion
Sponsored by:
Sponsored by:
Gremlin???
Old 02-14-2015, 06:33 PM
Jeff W's Avatar
Default Gremlin???
I have a 2001 Audi TT which has not run right since a few different repairs. The key was re-coded, as it was lost while repairs were being made(yesterday). Symptoms are:
Car races to high, high rpm on start-up
Accelerator pedal seems either disconnected or in limp mode.
If you don't make it to the bottom of the vag-com data, I am open to wild guesses, prayers, magic, black magic, and whatever else you might think handy. Most puzzling is the "No redir" at the very top of the ecm DTC listing. Thanks in advance, J Witt
VCDS-Lite Version: Release 1.2
Saturday, 14 February 2015, 14:12:33.
Control Module Part Number: 8N8 962 267 A
Component and/or Version: Central Lock/Alarm D06
Software Coding: 15884
Work Shop Code: WSC 00050
VCID: 3FF1C0FF2E65
9 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01374 - Shareware Version. To Decode all DTCs
35-00 - Please Register/Activate
01370 - Shareware Version. To Decode all DTCs
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Shareware Version. To Decode all DTCs
01616 - Shareware Version. To Decode all DTCs
36-10 - Please Register/Activate - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
01559 - Shareware Version. To Decode all DTCs
58-00 - Please Register/Activate
00849 - Shareware Version. To Decode all DTCs
31-00 - Please Register/Activate
Saturday, 14 February 2015, 16:09:23.
Chassis Type: 8N - Audi TT
Scan: 01,02,03,08,15,17,22,35,37,45,55,56,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8N0 906 018 K
Component: 1.8L R4/5VT G 0003
Coding: 06710
Shop #: WSC 24338
VCID: 3905AEE73041
TRUWT28N511041187 AUZ5Z0A3020023
6 Faults Found:
18039 - Accelerator Position Sensor (G79): Signal too High
P1631 - 35-00 - -
18042 - Shareware Version. To Decode all DTCs
P1634 - 35-00 - Please Register/Activate
16727 - Shareware Version. To Decode all DTCs
P0343 - 35-00 - Please Register/Activate
17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit
P1116 - 35-00 - -(I intentionally unplugged it to see if it was my problem) NO CHANGE
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-00 - Please Register/Activate
16518 - Shareware Version. To Decode all DTCs
P0134 - 35-00 - Please Register/Activate
Readiness: 0110 1101
Address 03: ABS Brakes Labels: None
Controller: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18446
Shop #: WSC 06201
VCID: 3E0FBDFB296F
1 Fault Found:
00778 - Steering Angle Sensor (G85)
62-00 - No or Incorrect Adjustment
Old 02-19-2015, 06:48 AM
HowdyAudi27's Avatar
Might be too simple. But worth trying if you haven't. Clear the faults and re-adapt the throttle body. Should be Basic Settings, Group 60
Xenogen
05-14-2007 05:01 PM
CWTech
9
04-09-2007 04:44 AM
Redgoat
VAG-COM Discussion
09-29-2005 08:50 AM
superv
VAG-COM Discussion
11-19-2004 07:58 AM
huwla
08-31-2004 03:06 PM
Quick Reply: Gremlin???
