Grrr... Air conditioner stopped working yesterday...
Anything I can do to diagnose it via VAG-com? I ran it last night, but no fault codes came up. Am I missing something simple?
On another pleasant note, the driver's window regulator went out about ten minutes after the AC stopped working.
Hooooraaaaay!!!
Hooooraaaaay!!!
The AutoScan will grab info including faults from all controllers in the car.
There may be relevant stuff in other parts of the car, like the Engine.<ul><li><a href="http://www.ross-tech.com/vcds/tour/autoscan.html">http://www.ross-tech.com/vcds/tour/autoscan.html</a</li></ul>
Andy
Andy
Ok - here it is...
From last night...
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUPL68E34A130313 Mileage: 67350km/41849miles
Address 01: Engine Labels: Redir Fail!
Part No SW: 8E0 910 560 A HW: 8E0 907 560
Component: 4.2L V8/5V G 0020
Coding: 0007711
Shop #: WSC 07417 444 58627
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 Q
Component: ABS/ESP allrad 3033
Coding: 04595
Shop #: WSC 06435
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1319
Coding: 00000
Shop #: WSC 63351
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
1 Fault Found:
02104 - Light Detection Sensor (G399)
29-10 - Short to Ground - Intermittent
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 A
Component: SDAR XM 0010
1 Fault Found:
02635 - Tuner Not Enabled/Activated
35-10 - - - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
Shop #: WSC 63351 000 00000
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01041
Shop #: WSC 63351
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 980 M
Component: KOMBI+WEGFAHRS. RB4 D37
Coding: 03200
Shop #: WSC 07117
WAUPL68E34A130313 AUZ6Z0C0281193
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63351
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1411
Coding: 11818
Shop #: WSC 63351
Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0003
Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0003
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0004
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0004
3 Faults Found:
01369 - Alarm triggered by Hood Switch
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0400
Coding: 01220
Shop #: WSC 23040
1 Fault Found:
01303 - Telephone Transceiver (R36)
49-00 - No Communications
End ---------------------------------------------------------------------
...and here is one from just now...
69 75 76 77
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
Coding: 00002
Shop #: WSC 63351
69 75 76 77
Coding: 0007711
Coding: 04595
Shop #: WSC 06435
Coding: 00000
Shop #: WSC 63351
Coding: 01013
Shop #: WSC 63351
1 Fault Found:
1 Fault Found:
Coding: 0010607
Coding: 01041
Shop #: WSC 63351
Coding: 03200
Shop #: WSC 07117
Coding: 00002
Shop #: WSC 63351
Coding: 11818
Shop #: WSC 63351
Part No: 8E1959801
Part No: 8E1959802E
Part No: 8E0959801A
Part No: 8E0959802A
3 Faults Found:
35-00 - -
35-00 - -
35-00 - -
Coding: 00060
Shop #: WSC 63351
Coding: 01220
Shop #: WSC 23040
1 Fault Found:
69 75 76 77
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
Coding: 00002
Shop #: WSC 63351
What values do you have in...
...the climate control (#08) measuring blocks 001 and 002 while idling?
BTW: You may want to update to the latest version of VCDS, which is Release 805.<ul><li><a href="http://www.ross-tech.com/vcds/download/current.html">http://www.ross-tech.com/vcds/download/current.html</a</li></ul>
Here they are...
AC on lo (full speed)
Address 08: Auto HVAC (8E0 820 043 AD)
19:45:07 Group 001
0.652 A A/C Valve (N280) Current
64.0 % A/C Valve (N280) Duty Cycle
23.0 % High-Pressure Signal (G65)
6.0 bar Refrigerant Circuit Pressure
19:45:07 Group 002: Last Compressor Shut-Off Criteria
0.0 Current Criteria
0.0 Last Criteria
0.0 Last but one Criteria
0.0 Last but two Criteria
Wednesday,02,July,2008,19:45:47:15984
VCDS Version: Release 805.0
Data version: 20080529
AC off...
19:45:45 Group 001
0.000 A A/C Valve (N280) Current
0.0 % A/C Valve (N280) Duty Cycle
19:45:45 Group 002: Last Compressor Shut-Off Criteria
6.0 Current Criteria
0.0 Last Criteria
19:45:07 Group 001
0.0 Last Criteria
AC off...
19:45:45 Group 001
0.0 Last Criteria
Zero cold air at all. It was working fine when I was driving, I turned it off for a few minutes
to roll down the windows, and then rolled them up a few minutes later, and had no cold air. Still don't - it only blows hot / warm. No new or odd noises that I can detect, either.
cutchemist42
06-07-2013 04:19 AM
Python021
03-09-2012 05:37 AM
DoubleB
VAG-COM Discussion
03-10-2009 04:48 AM
002, 8e0035593xmlbl, a3, air, audi, compressor, conditioner, criteria, group, last, quit, shutoff, stopped, working
