VAG-COM Discussion
Sponsored by:
Sponsored by:
HELP with Codes
Old 03-03-2007, 01:15 PM
New Member
guido_TT's Avatar
Default HELP with Codes
Here is what i pulled off the VAG this afternoon.
Saturday, 03 March 2007, 13:17:44
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8N0 906 018 M
Component and/or Version: 1.8L R4/5VT G 0005
Software Coding: 06500
Work Shop Code: WSC 01236
2 Faults Found:
16806 - Main Catalyst: Bank 1: Efficiency Below Threshold
P0422 - 35-00 - -
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
Old 03-04-2007, 10:35 AM
Theresias's Avatar
Default Been here yet?
<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">http://wiki.ross-tech.com/index.php/Category:Fault_Codes</a</li></ul>
Old 03-05-2007, 12:55 PM
New Member
guido_TT's Avatar
Default Re: Been here yet?
Nothing on that page pertaining to the codes that i pulled. 17536 isn't even on there.
Old 03-05-2007, 01:43 PM
Theresias's Avatar
Double check the site and you will find what you searched for.
Old 03-06-2007, 05:00 AM
Audiworld Premium Sponsor
Uwe@Ross-Tech.com's Avatar
Default On a silver platter
http://wiki.ross-tech.com/index.php/16806/P0422/001058
http://wiki.ross-tech.com/index.php/17536/P1128/004392
http://wiki.ross-tech.com/index.php/Fuel_Trim_Info
-Uwe-
http://www.Ross-Tech.com
Old 03-06-2007, 08:13 AM
New Member
guido_TT's Avatar
Default Re: On a silver platter
Is there a block you can log for Fuel Injectors, or do you think they should be manually pulled out and inspected? thnx.
Old 03-06-2007, 02:04 PM
Default What exactly do you expect to log from your fuel injectors?
The ECU knows how long it turns 'em on for (Group 002, field 3), but as far as actual quantity of fuel injected, there's no sensor for that.
-Uwe-
Old 03-07-2007, 10:39 AM
New Member
guido_TT's Avatar
Default Re: What exactly do you expect to log from your fuel injectors?
it seems like I have replaced everything that has to do w/ my problem. Spark plugs, fuel filter, MAF Sensor, o2 sensor, had everything under the hood smoked for leaks... 3 leaks found and all were fixed. I am just trying to find out why i get the lean code. If i erase the codes i'll be fine until i get on the highway and do 55, not even boosting full load, just babying it. my next guess: fuel pump/injectors are bad?
Old 03-07-2007, 04:23 PM
Default Have you done a full-load MAF test?
I know you said you replaced the MAF but it wouldn't be the first time that a replacement wasn't any good and 17536 is most often associated with a bad MAF.
Have you checked your fuel pressure?
What do you long term fuel trims look like after a few days of driving without clearing codes?
-Uwe-
Old 03-08-2007, 11:19 AM
New Member
guido_TT's Avatar
Default Re: Have you done a full-load MAF test?
well, i dropped my car off to a german specialist (who did my software and builds NOBLE M12's). He said he dropped a good MAF in there and tested it out but made absolutely no difference. How do you check Fuel pressure w/ VAG? what block to log for fuel trims?
Quick Reply: HELP with Codes
