Help With Recoding Instrument cluster
I finally got VAG-COM and want to fix some things that have been bothing me for a while now. I had my instrument cluster replaced a while back with a used one. Ever since the Tach has been off substaintally. I assume it is the soft coding, however i dont have the old soft coding for the car. Its a 1998.5 1.8TQ TIPTRONIC. The current Soft coding is 03262. Help would be greatly appreciated. Was also wondering if it was possible to Change the Odometer, mine is about 50K less than it should be due to the change.
change the 6 to a 4....
First two digits are dependent on your optional equipment (pad wear indicator, washer level, seat belt warning system). If all of that seems to be working as it was, then change to 03242, and you should be ok.
Nothing you can really do about the odometer.
revisiTTed
12-07-2008 03:52 PM
Texas Twin T
05-18-2006 04:07 AM
allaudiguy
11-07-2004 10:48 PM
ex-quattro PETE
VAG-COM Discussion
07-01-2003 07:56 PM
