HOW DO YOU RESET THE SERVICE LIGHT ON A 2003 AUDI A3 2.OL FSI
It's the same as all modern Audi (last 5-6 years):
Select -> 17 Instruments -> Adaption -> Channel 02 -> New Value 0 -> Test -> Save.
-Uwe-
PS: Your CAPS LOCK key seems to be stuck.
-Uwe-
http://www.Ross-Tech.com
This ones not the same.
Reseting channel 2 to 0 does not afect the service light, there are no faults with dash and when i paid Audi a large fee to do it they did it in about 2 mins.
P.S My cApS lOcK BuTtoN iS FinE
Re: This ones not the same.
Hi M-Tech,
As I'm not getting any help I may as well try to help others.
I hope this is relative to your A3, if not, please ignore.
Do you have 2 buttons on the dash display? ie. one on the left , to the lower right of the rev counter (let us call that button 1) AND, one to the right, to the lower left of the MPH/KPH display (let's call that button 2).
If so, press and hold button 2,
Switch ignition ON,
Release button 2,
The words "SERVICE" or SERVICE IN xxxx MI will appear in the trip meter,
Turn button 1 to the left to clear the display.
The words "SERVICE IN 10 000 MI" should appear in the trip meter
Now switch ignition off
hope this helps,
let me know how things go,
Ecu320i
Switch ignition ON,
Release button 2,
hope this helps,
Ecu320i
Please make an Adaptation Channels Map and e-mail it to me.
Using VAG-COM version 512:
Applications -> Controller Channels Map,
Address 17, Adptation, CSV File
-Uwe-
-Uwe-
Reset service light indicator Audi A3, 1996 - 2009
The full procedure how to reset service light indicator Audi A3. If you like to reset any maintenance oil light after an oil change, or reset check engine light, airbag light, inspection key or insp errors when maint reqd, for Audi cars. How to reset any error which appears on the dash board display.
http://resetservicelight.com/reset-s...cator-audi-a3/
ICONCLS
RS 6 Discussion (C5)
43
02-24-2006 11:29 AM
no.radar
09-26-2003 07:30 AM
