VAG-COM Discussion
Sponsored by:
Sponsored by:
unable to code new DME Control Unit
Old 01-24-2006, 09:47 AM
New Member
DEZSCOTT's Avatar
Default unable to code new DME Control Unit
I have purchased a new DME control unit for a 2000 Jetta 2.0l. The unit came coded for an automatic transmission and this is a manual. I beleve that I have the correct code - 00031, but the will not new code. Has anyone seen this or an I missing somethig. Any help will be welcome. Thank you Scott
Old 01-24-2006, 09:59 AM
Theresias's Avatar
DME? Talking about an ECU (engine control unit)?
Old 01-24-2006, 10:02 AM
New Member
DEZSCOTT's Avatar
Default Re: DME? Talking about an ECU (engine control unit)?
Yes the ECU - Sorry I was speaking BMW.
Old 01-24-2006, 10:06 AM
Theresias's Avatar
New units are not coded, so you got a used one. Part number of the new ECU? Same as the old one?
Old 01-24-2006, 10:15 AM
New Member
DEZSCOTT's Avatar
Default Re: New units are not coded, so you got a used one. Part number of the new ECU? Same as the old one?
I purchased this unit from the dealer and it came in a new unopened box. The part numbers match. So I believe that it is a new unit. Even if it was a used unit I still should be able to recode it?
Old 01-24-2006, 09:01 PM
Theresias's Avatar
Default If the part numbers match, you should be able to code it.
What are the part numbers (read them via diagnostics)?
What is their current coding?
Old 01-25-2006, 07:10 AM
New Member
DEZSCOTT's Avatar
Default Re: If the part numbers match, you should be able to code it.
The part numbers are 06A 906 018 ET. The current coding is 00023 and it needs to be 00031. Do I need to login to change the coding in this control unit?
slowpoke
Audi allroad
10-13-2008 07:29 PM
aboantar
VAG-COM Discussion
05-15-2008 01:14 PM
AVANT S4 KING
11-02-2006 08:21 PM
KramS4
VAG-COM Discussion
10-13-2006 12:15 AM
captainbilly
04-01-2001 07:15 PM
Quick Reply: unable to code new DME Control Unit
