VAG-COM Discussion
Sponsored by:
Sponsored by:
18010 - Power Supply Terminal 30: Voltage too Low. Any ideas where I could look to find the problem?
Old 08-01-2006, 01:19 PM
New Member
q20v18t's Avatar
Old 08-01-2006, 02:30 PM
Theresias's Avatar
Details please! Which car? Model year? Engine type/code? Which control module?
Old 08-01-2006, 03:37 PM
New Member
q20v18t's Avatar
Default 1998 A4 1.8TQ AEB.......more info
Address 01: Engine
Part No: 8D0 907 557 P
Component: 1.8L R4/5VT MOTR HS D07
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Old 08-02-2006, 05:16 AM
Bracketracer's Avatar
Default do you have a check engine light on?
I see these codes a few times a week on cars that have had a low battery within the past month.
Old 08-02-2006, 05:59 AM
Audiworld Premium Sponsor
Andy@Ross-Tech's Avatar
Yep, low battery or recently disconnected ecu are frequent culprits.
Andy
Old 08-02-2006, 12:35 PM
New Member
q20v18t's Avatar
I removed the battery a day ago to clean the drains under it...think I should get a new one?
New Member
q20v18t's Avatar
No I do not
Old 08-02-2006, 12:36 PM
New Member
q20v18t's Avatar
WOT about 70% or more, it really cuts out and the car shutters like its misfiring
Old 08-02-2006, 01:04 PM
Theresias's Avatar
No, but that explains the fault code.
Old 08-02-2006, 03:55 PM
New Member
q20v18t's Avatar
But then what would cause the car the shutter like that?
Quick Reply: 18010 - Power Supply Terminal 30: Voltage too Low. Any ideas where I could look to find the problem?
