keyless entry update: tried both channells 1 and 21 and both read error not available
I suspect my keyless entry controller is toast.
Any other ideas, anyone??
Here are the dtc's I cleared.
4 DTCs Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm via Door Contact Switch: Driver Side
35-00 - -
01370 - Alarm via Interior Scan
35-00 - -
00955 - Key 1 Adaptation Limit Exceeded
09-00 - Adaptation Limit Surpassed
Both Channel 01 and 21 for reprogramming remotes with VAG-COM come up as Error Not Available.
4 DTCs Found:
35-00 - -
35-00 - -
35-00 - -
OK, it seems that on your car,
the matching is done with the kludgy "2-key, outside the car" method. It's a bit too complicated to post here, but you'll find it on the Bentley CD.
Check your e-mail too.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
oppy
12-03-2006 07:23 AM
Pekboy
03-03-2004 01:14 PM
QuiksilverS4
VAG-COM Discussion
06-09-2003 11:39 AM
QuiksilverS4
05-30-2003 07:53 AM
dohc
02-23-2003 06:08 PM
