MAXIMUM PRESURE EXCHEDEED
i have an A31.6 2001 MODEL.RECENTLY I VE PUT THE ENGINE OF S3 99 MODEL WITH WITH GEARBOX BRAKES ECU ALL THE CONVERTION.MY PROBLEM IS THAT WHEN I PUSH IT AND PARTICURARLY WITH 4TH GEAR IN 4000TURNS MY CAR SLOW DOWN WITH LESS POWER AND WHEN I PUT THE DIAGNOSTIC IT SAYS "MAXIMUM PRESURE EXCEEDEED"THE ONLY THING I HAVE CHANGE TO THE CAR IS THE EXCHAUST THE SECOND AND THE LAST PART 62.5 HANDMADE.THE CATALYT IS THE S3 I DIDNT CHANGE IT.PLEASE I CANT FIND THE PROBLEM.IS IT A PROBLEM WITH ECU.NEED A PROGRAMM?
First off, turn your caps lock off. Second, you've got the overboost error...
... and it is most likely something that is part of the boost control system like the n75 valve or the by-pass valve or the vacuum lines to/from those valves.
Kirk
Kirk
Quattrings
01-17-2016 12:42 AM
ArnottDoug
Suspension Tuning Discussion
09-23-2015 05:48 AM
ArnottDoug
09-23-2015 05:37 AM
