My Scan
My Scan
Hi, need to get this ABS sorted. Already replaced sensors and brake light switch. Basically just need someone to say, "No worries. Just replace/check this and you're good to go"
N75 valve on it's way for that over boosting.
2000TT APX-225
Cheers.
code.Wednesday,05,June,2013,19:09:32:50382
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 8N - Audi TT
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: XXXXXXXXXXXXXXXXX
Address 01: Engine Labels: 06A-906-032-APX.clb
Part No: 8L0 906 018 M
Component: 1.8L R4/5VT G 0002
Coding: 05710
Shop #: WSC 01236
VCID: 3979F433239D5CD0275
2 Faults Found:
18057 - Powertrain Data Bus
P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
17963 - Charge Pressure
P1555 - 35-10 - Maximum Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V004
Coding: 18446
Shop #: WSC 01236
VCID: 3E73E72F3AB37BE8127
2 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
00778 - Steering Angle Sensor (G85)
49-00 - No Communications
Address 08: Auto HVAC Labels: 8N0-820-043.lbl
Part No: 8N0 820 043 A
Component: TT-KLIMAVOLLAUTOMAT D03
Coding: 00041
Shop #: WSC 01236
VCID: 285F2177C837D55848B
No fault code found.
Address 15: Airbags Labels: 8N8-909-601.lbl
Part No: 8N8 909 601
Component: Airbag Front+Seitd 1005
Coding: 00102
Shop #: WSC 01236
VCID: F7FDB20BD5090AA0911
Address 17: Instruments Labels: 8Nx-920-xxx-17.lbl
Part No: 8N2 920 880 H
Component: KOMBI+WEGFAHRS. M73 D55
Coding: 07744
Shop #: WSC 21000
VCID: 3B75EE3B29A16EC0359
XXXXXXXXXXXXXXXXX AUZ5Z0C9086080
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F4D3AAB9D7912E0391
1 Fault Found:
01316 - ABS Control Module
Address 35: Centr. Locks Labels: 8Nx-962-267.lbl
Part No: 8N7 962 267
Component: Zentralverrieg.,DWA D04
Coding: 05848
Shop #: WSC 24440
VCID: FDF1A023F73520F0CBD
1 Fault Found:
01560 - Passenger Door
60-00 - Won't Safe
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8N7 951 177
Component: Innenraumueberw. D14
Coding: 00001
Shop #: WSC 00000
VCID: FBF5AE3BE9212EC0F59
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00010
Shop #: WSC 01236
VCID: E5C1E8437FA5883033D
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186 D
Component: Radio D05
Coding: 00017
Shop #: WSC 01236
VCID: 21493C53AB0D24100F5
End ---------------------------------------------------------------
2000TT APX-225
Cheers.
Coding: 05710
Shop #: WSC 01236
2 Faults Found:
Coding: 18446
Shop #: WSC 01236
2 Faults Found:
00-00 - -
Coding: 00041
Shop #: WSC 01236
Coding: 00102
Shop #: WSC 01236
Coding: 07744
Shop #: WSC 21000
No Faults Found
1 Fault Found:
Coding: 05848
Shop #: WSC 24440
1 Fault Found:
60-00 - Won't Safe
Coding: 00001
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 01236
Coding: 00017
Shop #: WSC 01236
RedRummy
VAG-COM Discussion
14
06-23-2010 05:48 AM
