Need help with codes misfire 2.7T please help!
Address 01: Engine
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0020
Coding: 07755
Shop #: WSC 07117
5 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16690 - Cylinder 6: Misfire Detected
P0306 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 000
Check engine light flashes
Car idles like crap then when you get above 35 mph it runs like nothing is the matter but under 35 mph or low RPMS it stutters makes little boost.
I replace all my spark plugs on sat and its still misfire.
Could it be the coilpacks?
I read somewhere on here that someone had a similar problem and it was the timing belt had jumped a tooth and caused the car to run like crap at low RPMS. I have not changed my timing belt yet but the car is at 77,000. Any help would awesome. I just want to have a idea of what wrong so i can figure out if i can fix it my self or take it somewhere.
Coding: 07755
Shop #: WSC 07117
5 Faults Found:
P0300 - 35-00 - -
P0306 - 35-00 - -
Readiness: 0000 000
AlvaroJ
02-17-2012 05:17 PM
Loseph
Audi allroad
10
07-18-2008 04:40 PM
EuropaA4Quattro
04-19-2007 02:42 PM
