need help with figuring out possible cause for fault codes
I recently around this time did a K04 turbo upgrade doing bench flash ecu. Here's the code that I receive several days later. All seem to be tied to either the ECU flash or K04 turbo install? any feedback will be greatly appreciated.
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
Address 01: Engine (0-----CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H20 0002
Revision: E1H20---
Coding: 0121010A290F0160
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ECM20TFS0118R0907115P 001002
ROD: EV_ECM20TFS0118R0907115P.rod
VCID: 4189B023D05EEB29211-8014
3 Faults Found:
4698 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 92380 km
Date: 2015.05.12
Time: 16:12:41
4699 - Function Restriction due to Faults in Other Modules
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 92380 km
Date: 2015.05.12
Time: 16:12:42
7229 - Cam Adjustment Actuator B; Cylinder 1
P11A4 00 [109] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 92381 km
Date: 2015.05.12
Time: 16:16:40
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 H HW: 8R0 907 379 H
Component: ESP8 quattro H06 0110
Revision: -------- Serial number: --------------
Coding: 121D18
Shop #: WSC 06334 000 00000
VCID: 4581A433CC76C7091D9-8010
2 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 92379 km
Time Indication: 0
Date: 2015.05.12
Time: 15:57:31
Freeze Frame:
Hex Value: 0x4600
Hex Value: 0x4006
Hex Value: 0x120A
Hex Value: 0x46B5
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 92379 km
Time Indication: 0
Date: 2015.05.12
Time: 15:57:32
Freeze Frame:
Hex Value: 0x4A00
Hex Value: 0x6206
Hex Value: 0x1216
Hex Value: 0x02B4
Hex Value: 0x00FF
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AH HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0120
Revision: EC101057 Serial number: 5700E11B078070
Coding: 00C303
Shop #: WSC 06335 000 00000
VCID: 071D6E3BB6FA15192F5-8052
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 240
Mileage: 92377 km
Time Indication: 0
Date: 2015.05.08
Time: 17:29:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.30 V
Count: 17
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000001059268
VCID: 3467E9F797EC4E81BA7-8061
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 241
Mileage: 92379 km
Time Indication: 0
Date: 2015.05.12
Time: 15:57:32
Freeze Frame:
Voltage: 14.50 V
Count: 58
Speed: 74.0 km/h
Hex Value: 0x0260
Hex Value: 0x0004
Hex Value: 0x0101
personal notes:
01314 - Engine Control Module: Check DTC Memory
Possible Causes
## Fault(s) stored in Engine Control Module
Possible Solutions
## Check Engine Control Module for Fault Codes
Special Notes
## Engine Control Module stored a Code which influences other Control Modules Functionality.
## To clear this Fault Code you will need to correct the Problem in the Engine Control Module first.
looks like all fault codes for timestamp of 15:57 REPORTED on the 12th might be related to the bench flash that took place.
The car seems to ride fine. I've done scans of my vehicle from time to time and never had any fault codes except for a electrical related to a rear tail light bulb. My feeling is this is tied to the tune but wanted to get any one with similar experience with similar issues on their Audi. My car is a 2012 Audi Q5 2.0T.
Revision: E1H20---
3 Faults Found:
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 92380 km
Date: 2015.05.12
Time: 16:12:41
U1113 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 92380 km
Date: 2015.05.12
Time: 16:12:42
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Mileage: 92381 km
Date: 2015.05.12
Time: 16:16:40
Coding: 121D18
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 92379 km
Time Indication: 0
Date: 2015.05.12
Time: 15:57:31
Freeze Frame:
Hex Value: 0x4600
Hex Value: 0x4006
Hex Value: 0x120A
Hex Value: 0x46B5
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Mileage: 92379 km
Time Indication: 0
Date: 2015.05.12
Time: 15:57:32
Freeze Frame:
Hex Value: 0x4A00
Hex Value: 0x6206
Hex Value: 0x1216
Hex Value: 0x02B4
Hex Value: 0x00FF
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 240
Mileage: 92377 km
Time Indication: 0
Date: 2015.05.08
Time: 17:29:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.30 V
Count: 17
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 241
Mileage: 92379 km
Time Indication: 0
Date: 2015.05.12
Time: 15:57:32
Freeze Frame:
Voltage: 14.50 V
Count: 58
Speed: 74.0 km/h
Hex Value: 0x0260
Hex Value: 0x0004
Hex Value: 0x0101
personal notes:
Possible Causes
Possible Solutions
Special Notes
Does anyone know if the fault codes showing up last occurrence of an earlier time frame, is that indication that the problem no longer exist since it's gone through cycles without the issue reoccurring or showing a fault code with the latest day/time? I've scanned several times around when I first discovered the fault codes, but never seen the date and time changed as far as last it was detected which was between 5/8-5/12. I'm having dealer look into issue, but they report not seeing this specific error code (ie. cam adjustment actuator fault code) when they put it through their scan tool. They did the scan either yesterday or today. Could this be false alarm at this point? I'm assuming their scan tool should have given the fault code if the problem still exist correct? If someone can shed some light, I would appreciate it.
hurdlrstud
06-05-2017 01:42 PM
cocoliso
01-21-2003 12:04 PM
