New to HEX-COM, how to get rid of this message?
<center><img src="http://pictureposter.audiworld.com/47676/xenon.jpg"></center><p>I have a 2003 A4 3.0, I would like to reset this code (Xenon auto-leveling) (see attached pic). I'm asking some help since I read the manual but not sure what to do and for now, I don't want to screw up everything!
Sylvain
Sylvain
Select Control Module, Less Common Modules, Elec. Ctrl. Mod., Fault Codes.
Note the any error codes to see what they may be, clear the codes. And then see if it error goes away... If it comes back, there's something more involved than a fault code.
Here is how to fix this in an A6 -- it might work for you
This is a common error condition when you adjust your xenons without putting the lighting computer into "adjust mode".
Here is the sequence for an A6.
PARK CAR ON LEVEL GROUND - LOADED NORMALLY
Use VAG to select module 55 Lighting level control
Enter 02 - Clear DTC's
Enter 04 - basic settings
activate function 001 (enter 001, click "go")
(now you can set your lights manually)
activate function 002
Your lights are now calibrated for their new position!
That works for the B6 A4 as well. Also documented in the Tech section (see link)
<ul><li><a href="https://www.audiworld.com/tech/misc29.shtml">https://www.audiworld.com/tech/misc29.shtml</a</li></ul>
johnd64
09-24-2015 09:21 PM
