New with VCDS experience
Car is running fine just one problem which i post in different thread
Can anyone guide me through this scan ..... i did with engine running.
Thank you
Saturday,18,May,2013,16:26:02:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1D 1E 25 28 34 36 37 38
42 46 47 4F 52 53 55 56 57 61 62 65 67 72 76 77
VIN: WAUML44E64N321968 Mileage: 176200km/109485miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: Cannot be reached 1100
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 F HW: 4E0 907 560
Component: 4.2L V8/5V G 0050
Revision: 00000000 Serial number: AUX3Z0C4216961
Coding: 0005773
Shop #: WSC 00020 724 95953
VCID: 244DF249E7C0DE9
4 Faults Found:
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 001 - System too Lean - MIL ON
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 001 - System too Lean - MIL ON
16825 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Readiness: 0000 1000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V RdW 0120
Revision: 00000001 Serial number: 0015437
Coding: 0000001
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 00020 000 00000
VCID: 2143FB5DF8D2CB1
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 E
Component: FBS AUDID3 H02 0120
Revision: 01203602 Serial number: AUX3Z0C4216961
Coding: 0409600
Shop #: WSC 02311 785 00200
VCID: D8B516B96B08CA9
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063840
Shop #: WSC 02313 785 00200
VCID: 234FF155E2CED91
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 L HW: 4E0 035 729 A
Component: Interfacebox H43 3460
Revision: 00000000 Serial number: 300F3037522030
Coding: 0000002
Shop #: WSC 00020 724 89755
VCID: 2B5F19758A1E111
Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
1 Fault Found:
02750 - Switch for Display Head
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 171512 km
Time Indication: 0
Date: 2013.03.21
Time: 11:57:12
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 015 0240
Revision: 00000017 Serial number: 00000000019931
Coding: 0037113
VCID: DAB10CB11504D89
Part No: 4E0 910 772
Component: Sitzluefter FS H05 010
Component: Sitzluefter BFS H05 010
1 Fault Found:
00565 - Rear A/C Control Head (Climatronic) (E265)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 151785 km
Time Indication: 0
Date: 2012.08.14
Time: 21:34:37
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111001
VCID: 2A511C7185E4089
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H09 0940
Coding: 0431707
VCID: E3CF3155224E191
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H09 0030
Coding: 0012141
VCID: E5CB2F4D2C7A671
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 900 E
Component: KOMBIINSTR. VDO H42 0070
Revision: D08 Serial number: AUDID3C5015885
Coding: 0000601
Shop #: WSC 11986 111 00001
VCID: DCBD0AA91F30269
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 3
Reset counter: 252
Mileage: 175729 km
Time Indication: 0
Date: 2003.03.15
Time: 23:12:05
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0050
Revision: 07 Serial number: 13003036110E76
Coding: FCFF7FDD2B7504
Shop #: WSC 00020 724 71518
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 215
Mileage: 169787 km
Time Indication: 0
Date: 2003.03.03
Time: 20:38:10
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 227
Mileage: 173165 km
Time Indication: 0
Date: 2013.04.20
Time: 13:14:22
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 HW: 4E1 905 218
Component: FPI_1 H04 0060
Revision: 06000104 Serial number: 17062003105635
Shop #: WSC 00000 000 00000
VCID: DEB900A1092C349
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Serial number: AUZ5ZBC1017342
VCID: 1C3DCAA9DFB0E69
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 6
Reset counter: 144
Mileage: 172748 km
Time Indication: 0
Date: 2013.04.07
Time: 17:25:37
Freeze Frame:
Text: 00000000
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0409600
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 28: HVAC, Rear
Cannot be reached
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 11986 111 178380
VCID: 254BEF4DECFA271
3 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 102
Reset counter: 238
Mileage: 169814 km
Time Indication: 0
Date: 2003.03.05
Time: 16:44:04
01487 - System Function Test
Freeze Frame:
Fault Status: 11101111
Fault Priority: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 239
Mileage: 170192 km
Time Indication: 0
Date: 2003.04.04
Time: 05:00:45
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H06 0060
Coding: 4063854
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 C HW: 4E0 919 887 C
Component: MNS ECE H41 0350
Revision: 00000000 Serial number: 305FL037536038
VCID: 2D5B176DB40A1F1
1 Fault Found:
02445 - Disk Drive Initialization Error
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 0
Mileage: 172899 km
Time Indication: 0
Date: 2013.04.14
Time: 11:53:44
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0080
Serial number: 00000315400157
Coding: 0003798
VCID: 1D3BC7ADC4AAEF1
1 Fault Found:
02139 - Control Circuit for Left Front Interior Lights
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 124
Mileage: 171744 km
Time Indication: 0
Date: 2013.03.24
Time: 13:54:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0100
Coding: 0028453
2 Faults Found:
02124 - Exterior Door Handle Switch
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 173
Mileage: 150864 km
Time Indication: 0
Date: 2012.08.04
Time: 21:31:24
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 217
Mileage: 175152 km
Time Indication: 0
Date: 2003.03.02
Time: 01:25:38
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040306260124
Coding: 0004712
VCID: 2757E54596F6351
Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
2 Faults Found:
00892 - Switch for Trunk Closing Cylinder (F248)
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 190
Reset counter: 215
Mileage: 169787 km
Time Indication: 0
Date: 2003.03.03
Time: 21:02:49
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 37
Reset counter: 215
Mileage: 175970 km
Time Indication: 0
Date: 2003.03.20
Time: 08:57:41
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000181873
Coding: 0000026
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H07 0070
Revision: Serial number: 00000000016917
Coding: 0010101
VCID: DDBB07AD042A2F1
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0100
Coding: 0028453
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000531
Address 55: Xenon Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Coding: 0000002
VCID: E2C134513D54109
1 Fault Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 169784 km
Time Indication: 0
Date: 2003.03.03
Time: 20:41:30
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0620
Revision: 00000000 Serial number: 304FQ037535369
Coding: 0000001
VCID: 2E591061B90C649
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 F HW: 4E0 919 146
Component: TV analog TUNER H12 0290
Revision: 00000061 Serial number: 00000000000000
Coding: 0001014
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000008671
Shop #: WSC 00020 724 68387
VCID: 1F47FDA5CEA6FD1
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 391011B062
Coding: 303030393135313035414B56413033393130313142303632
1 Fault Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 154195 km
Time Indication: 0
Date: 2012.09.03
Time: 22:25:52
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0090
Coding: 0028453
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212029
VCID: DFC73DA50E263D1
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 253
Reset counter: 215
Mileage: 172409 km
Time Indication: 0
Date: 2013.04.01
Time: 10:26:46
Freeze Frame:
Speed: 30.0 km/h
Temperature: 34.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 150891 km
Time Indication: 0
Date: 2012.08.06
Time: 04:56:33
Freeze Frame:
Speed: 125.0 km/h
Temperature: 35.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753
Component: SDS 3502 UK H43 0630
Revision: 00000000 Serial number: 00000306060186
Shop #: WSC 12336 024 394758
VCID: 36693801415C5C9
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0090
Coding: 0028453
2 Faults Found:
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 13
Reset counter: 234
Mileage: 175568 km
Time Indication: 0
Date: 2003.03.12
Time: 01:01:30
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 254
Mileage: 176176 km
Time Indication: 0
Date: 2003.03.22
Time: 23:13:18
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0101008
VCID: E0C53E593358029
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0770
Revision: 00000001 Serial number: 00000000000000
Coding: 0000004
VCID: 2241F451FDD4D09
End ---------------------------------------------------------------------
Thank you
Chassis Type: 4E0
Coding: 0005773
4 Faults Found:
Coding: 0000001
Coding: 0007597
Coding: 0409600
Component: ELV XXXX
Coding: 4063840
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 171512 km
Time Indication: 0
Date: 2013.03.21
Time: 11:57:12
Coding: 0037113
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 183
Mileage: 151785 km
Time Indication: 0
Date: 2012.08.14
Time: 21:34:37
Freeze Frame:
ON
Coding: 0111001
Coding: 00000030
Shop #: WSC 02311
Coding: 0431707
Coding: 0012141
Coding: 0000601
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 252
Mileage: 175729 km
Time Indication: 0
Date: 2003.03.15
Time: 23:12:05
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Reset counter: 215
Mileage: 169787 km
Time Indication: 0
Date: 2003.03.03
Time: 20:38:10
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 227
Mileage: 173165 km
Time Indication: 0
Date: 2013.04.20
Time: 13:14:22
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 144
Mileage: 172748 km
Time Indication: 0
Date: 2013.04.07
Time: 17:25:37
Freeze Frame:
Text: 00000000
Coding: 0409600
Component: ELV XXXX
Cannot be reached
Coding: 0015510
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 238
Mileage: 169814 km
Time Indication: 0
Date: 2003.03.05
Time: 16:44:04
Freeze Frame:
Fault Priority: 0
Reset counter: 0
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 239
Mileage: 170192 km
Time Indication: 0
Date: 2003.04.04
Time: 05:00:45
Coding: 4063854
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 0
Mileage: 172899 km
Time Indication: 0
Date: 2013.04.14
Time: 11:53:44
Coding: 0003798
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 124
Mileage: 171744 km
Time Indication: 0
Date: 2013.03.24
Time: 13:54:00
Coding: 0028453
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 173
Mileage: 150864 km
Time Indication: 0
Date: 2012.08.04
Time: 21:31:24
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 217
Mileage: 175152 km
Time Indication: 0
Date: 2003.03.02
Time: 01:25:38
Coding: 0004712
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 215
Mileage: 169787 km
Time Indication: 0
Date: 2003.03.03
Time: 21:02:49
Freeze Frame:
Fault Priority: 3
Fault Frequency: 37
Reset counter: 215
Mileage: 175970 km
Time Indication: 0
Date: 2003.03.20
Time: 08:57:41
Coding: 0000026
Coding: 0010101
Coding: 0028453
Revision: AV1C1010
Coding: 0000531
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 87
Mileage: 169784 km
Time Indication: 0
Date: 2003.03.03
Time: 20:41:30
Coding: 0000001
Coding: 0001014
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Mileage: 154195 km
Time Indication: 0
Date: 2012.09.03
Time: 22:25:52
Coding: 0028453
Coding: 0212029
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Reset counter: 215
Mileage: 172409 km
Time Indication: 0
Date: 2013.04.01
Time: 10:26:46
Freeze Frame:
Speed: 30.0 km/h
Temperature: 34.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 150891 km
Time Indication: 0
Date: 2012.08.06
Time: 04:56:33
Freeze Frame:
Speed: 125.0 km/h
Temperature: 35.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028453
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 234
Mileage: 175568 km
Time Indication: 0
Date: 2003.03.12
Time: 01:01:30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 14
Reset counter: 254
Mileage: 176176 km
Time Indication: 0
Date: 2003.03.22
Time: 23:13:18
Coding: 0101008
Coding: 0000004
packge33
07-15-2012 12:17 PM
