NO DTC But...
NO DTC But...
02 A4 2.0 cvt with vagcom (704.1) 01 engine readiness showing "O2 SENSOR(S) FAILED OR INCOMPLETED" as well as "CAT. CONVERTER FAILED OR INCOMPLETED".But there is nothing indicated in the dashboard as well as not DTC after an auto scan with vagcom?? It is normal to happen on "OLD" sensor(s)? Will these increase the fuel consumption? Hoped that some big brother will give me a hand. Thanks in advance.
The purpose for the Readiness function is to check whether emissions-related systems are working.
If you have recently cleared fault codes, you will need to either perform a specific procedure, or drive several cycles including some highway driving before all will be reset.<ul><li><a href="http://www.ross-tech.com/vcds/tour/readiness.html">http://www.ross-tech.com/vcds/tour/readiness.html</a</li></ul>
Andy
Andy
Send an email to Santos@Ross-Tech.com if the Set Readiness button is grayed out:
<ul><li><a href="http://forums.vwvortex.com/zerothread?id=3686652">http://forums.vwvortex.com/zerothread?id=3686652</a</li></ul>
Andy
Andy
Re: The purpose for the Readiness function is to check whether emissions-related systems are working
Re: Set Readiness:
My son reports "The car drives like crap for three days after you disconnected the battery, Dad." (my self-esteem is injured!)
Do the Readiness bits affect engine operation / smoothness?
Also: why did VAG choose to store the Throttle Adaptation and Readiness in volatile memory?
To me, this seems to be shortsighted at best.
Car: 1998 Audi A4, US, AHA engine (2.8L 6cyl)
Thanks! - Jim Hutchison
Dr.Duct_Mossburg
Mid Atlantic Discussion
08-14-2006 08:58 AM
apenay
03-17-2006 02:58 PM
201-A4
01-16-2004 10:14 AM
eddiemac.net
07-07-2003 03:20 PM
cpayne
05-01-2002 07:16 PM
