What is cylinder voltage?
Audiworld Senior Member
Anyone clue me in on what cylinder voltage measures on vag? I'm getting random misfires on cylinders 4 and 6. If I clear the codes, I get them right back on start up. Minimal misfire but I can feel it at idle or holding steady moderate throttle. Started watching cylinder voltage and misfires and that was showing cylinder 5 misfiring and the voltages were a bit lower on cylinders 1 and 6. 06 C6 3.2.
Thanks,
AJG
Thanks,
AJG
I think it is likely injector voltages.
Which group were you looking at and what DTCs are showing up ?
More info on measuring blocks http://www.ross-tech.com/vag-com/m_blocks/
Those are generic codes, so I generally don't bother to look them up.
More info here: http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
That was my other thought, and lacking coffee this morning, totally forgot to mention it
maaliish
09-05-2006 02:18 PM
fourwheelslide
9
03-12-2006 02:25 PM
In an attempt to reduce cold start misfires, I reduced start up and warm up enrichment to 83.6%.....
PSmalls::DoggieStyle
13
10-17-2005 02:15 PM
