Parking Assist not working-fault codes--PLEASE HELP
Hi, I own a 2010 Audi Q5 Prestige S-Line. a couple of months ago my rear parking assist stopped working. The first symptom I noticed was a loud screech from the back of the car, when the car was put in reverse. A few days later my entire rear camera and all my parking assist sensors would not come on even if I pushed on the P button or put the car in reverse.
I went to Vag com my car today thinking I would be able to find the bad sensor and it seems that my 10 Com Park/Assist can't be reached.
In addition my engine light came on. It seems that one of my sensors needs to be changed.
I tried clearing the codes and here is my Vag Com details as below:
Friday,10,October,2014,16:16:52:02187
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
Mileage: 102560km-63727mi Repair Order:
Chassis Type: FP (8T0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 1B 36 3C 42 46 47 52 53
55 56 5F 62 69 6C 6D 72
VIN: WA1WKAFP7AA051905 Mileage: 102560km/63727miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Cannot be reached 1100
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CALB) Labels: 06E-907-559-CAL.clb
Part No SW: 8R0 907 559 G HW: 8F0 907 559 A
Component: 3.2 SIMOS8.2 H06 0004
Revision: --------
Coding: 0121000A190F0921
Shop #: WSC 25807 444 68113
ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
ROD: EV_ECM32FSI.rod
VCID: 448DB66ACF93543EFF5-8011
1 Fault Found:
8617 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
P2432 00 [039] - Short to Ground
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 102561 km
Date: 2014.10.10
Time: 16:06:56
Readiness: 1110 1101
Address 02: Auto Trans (J217) Labels: 0B6-927-156.clb
Part No SW: 8R0 927 158 F HW: 0B6 927 156
Component: 0B6 32 FSIUSA H05 0005
Revision: --H05---
Coding: 001012
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: 4085BA7ADB8B481EDBD-8015
No fault code found.
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 M HW: 8R0 907 379 M
Component: ESP8 quattro H06 0020
Revision: -------- Serial number: --------------
Coding: 04BD18
VCID: 4A919852E5B7824E059-801F
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DS HW: 8K0 907 064 DS
Component: BCM2 1.1 H02 0326
Revision: 00002001
Coding: 0D0500
VCID: 840DF66A0713143E3F5-80D1
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01291020090486
Coding: 46112000
VCID: 7AF10892F5D7D2CED59-802F
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H28 0380
Revision: 10028001 Serial number: 00000000379085
Coding: 26009015003CAF311F00080300001D0D4F9CE7480001016100 0000
Shop #: WSC 02609 444 14548
VCID: 3C7DCE8ABF632CFE875-8069
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 091019 H10 0041
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8R0 907 364 B HW: 8K0 907 364
Component: DAEMPFUNGS-SG H09 0053
Revision: 00000000 Serial number: 15100904670002
Coding: 050181
VCID: 3973D79EB05119D69C3-806C
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 D HW: 8R0 959 655 D
Component: AirbagVW-AU10 H39 0560
Serial number: 003FRD054FC8
Coding: 303633313432303030304A55304C38523053
ASAM Dataset: EV_AirbaAU10SMEAU416 002004
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 458BAB6EC4A96D36E8B-8010
Seat occupied recognition:
Subsystem 1 - Part No SW: 8R0 959 339 HW: 8R0 959 339
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R09000054K2
Crash sensor for side airbag; driver side:
Serial number: 6334MSME4A510759E
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME4A56220EH
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME3E412324A
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME48411728D
Crash sensor for front airbag; driver side:
Serial number: 63732SME65404102L
Crash sensor for front airbag; passenger side:
Serial number: 63832SME02422936S
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IJQ000J1
Coding: 000037
VCID: 3E79C482A97F3EEEA91-806B
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 980 K HW: 8R0 920 980 K
Component: KOMBIINSTR. H10 0255
Revision: 00000000 Serial number: CJK24PXA9
Coding: 8B1F22003300D705020000
VCID: 4183BF7ED8814116D43-8014
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AA HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0105
Revision: FB900055 Serial number: 5500F09A23005E
Coding: 00C303
VCID: 8005FA7A130B081E1BD-80D5
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0107
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 102561 km
Time Indication: 0
Date: 2014.10.10
Time: 16:06:55
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.50 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 D HW: 8K0 907 144 D
Component: DYNAMIKLENK. H06 0570
Revision: 50001005 Serial number: --------------
Coding: 820000
Shop #: WSC 06334 000 00000
VCID: 3065EABA632BD89E2BD-8065
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 8R0 959 760 B HW: 8R0 959 760 B
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001010021038
Coding: 00581B00000044440000
VCID: 4085BA7AD38B481EDBD-8015
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 8R0 907 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH10 0020
Revision: 00H10000 Serial number: 6PZ 009 014-05
Coding: 0010007
VCID: 3C7DCE8A7F632CFE875-8069
Subsystem 1 - Part No: 8R0 907 568 A
Component: J0770_SWA_Slave_H08 0020
Subsystem 2 - Serial number: 6PZ 009 014-25
Subsystem 3 - Serial number: 5F23.10.0900H080003CX10884ÿ
Subsystem 4 - Serial number: X10884ÿ
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009545271
Coding: 011D13205E00440004
VCID: 458BAB6ECCA96D36E8B-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0123332442
Coding: 0126063A207A749507B0053200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H01 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H01 0220
Address 47: Sound System (J525) Labels: 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AL HW: 8T0 035 223 H
Component: DSP Prem H09 0200
Revision: 00009001 Serial number: 34890000165102
VCID: 78F5129ACBDBC0DEA3D-802D
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009558100
VCID: 448DB66AC793543EFF5-8011
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000488680
Shop #: WSC 00000 000 00000
VCID: 346DE6AA9733E4BE4F5-8061
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000007
VCID: 346DE6AA5733E4BE4F5-8061
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335JR097536100
Coding: 020000010000000001
VCID: 1D3B230E04B945F690B-8048
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 8T1 035 664 B HW: 8T1 035 664 B
Component: H-BN-NA H45 0042
Revision: -------- Serial number: 490J3097531797
Coding: 010200060105E1EF55002B0E000000030000
VCID: 3777D1A686450FA66A7-8062
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 102561 km
Time Indication: 0
Date: 2014.10.10
Time: 16:07:00
Freeze Frame:
Bin. Bits: 00000100 00000000
Bin. Bits: 00000000 00000000
03278 - Functionality Limited due to Missing Messages
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 102561 km
Time Indication: 0
Date: 2014.10.10
Time: 16:07:05
Freeze Frame:
Bin. Bits: 00001000 00000000
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102203541
Coding: 010C13204000240004
VCID: 4281B072DD875A0ECD9-8017
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 B HW: 8K0 907 383 B
Component: Anhaenger H08 0080
Revision: 1A002002 Serial number: 00000117582968
Coding: 0200000000000000
VCID: 336FE5B6923DE38656F-8066
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H03--- Serial number: 525PA8-J99A1SH
Coding: 1031010
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 102561 km
Time Indication: 0
Date: 2014.10.10
Time: 16:06:54
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H27 0300
Revision: -------- Serial number: 8R0827851B
VCID: 3B7FCD96BA6D2BC68EF-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H27 0300
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102203454
End ---------------------------------------------------------------------
Thanks for all your help!!!
Revision: --------
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 102561 km
Date: 2014.10.10
Time: 16:06:56
Revision: --H05---
Coding: 001012
Coding: 04BD18
Revision: 00002001
Coding: 0D0500
Coding: 46112000
Coding: 01DD13
Coding: 024D25
Coding: 050181
Coding: 000037
Coding: 00C303
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 150
Mileage: 102561 km
Time Indication: 0
Date: 2014.10.10
Time: 16:06:55
Freeze Frame:
Bin. Bits: 11111
Voltage: 14.50 V
Count: 6
Bin. Bits: 10011
Time: 25.40 s
Coding: 820000
Coding: 0010007
Coding: 0000007
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 102561 km
Time Indication: 0
Date: 2014.10.10
Time: 16:07:00
Freeze Frame:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 102561 km
Time Indication: 0
Date: 2014.10.10
Time: 16:07:05
Freeze Frame:
Coding: 1031010
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 150
Mileage: 102561 km
Time Indication: 0
Date: 2014.10.10
Time: 16:06:54
Freeze Frame:
Term 15 On
Reverse OFF
Count: 3
I suspect your J446 has failed.
There hasn't been any water incursion or 'purple headliner' syndrome has there ?
Check the module to be sure it's getting power and is properly grounded, along with CAN bus connections.
An Optical Bus diagnostic should tell you more as I think the Q5 uses MOST.
SAI sensor short to ground, check for wiring damage first.
If all the traces look good (no impact damage, no fraying) then replace the sensor.
No there has not been any water incursion. I'm afraid I don't know what you mean by "purple headliner" syndrome but other than the rear parking assist and camera not coming on all the other electronics seem to be working fine. But could you please clarify what Purple headliner syndrome means?
I will check the Optical Bus diagnostic this weekend and report back.
Where is the SAI sensor? so I can look for that sensor and the wiring?
I still have the power train warranty in effect and was going to make an appt for reviewing that sensor error as I believe it would be covered by the warranty (true?)
Have seen a few threads on it in the model specific forums.
I have no idea where the sensor is - would have to look at erWin.
If you're still under warranty I would get Audi to do it
Thanks for running the diagnostic.
Am thinking you'll see Error next to the parktronic controller.
Hello JohnnyTyler24,
Were you able to get this resolved? What was the problem and how was it fixed? I have exactly the same issue (same exact VCDS log for address 6C), but I have no warranty, and would like to get this fixed as inexpensively as possible... AKA DIY!
Would very much appreciate the details of your resolution. Thank you very much,
Peter
Peter
bballfreak
9
04-14-2019 06:59 PM
