Is it possible to see why a code wont take? (Tip recode to 00012)
Hi Gang
Im trying to recode my MY2003 Allroad with tip and MFSW (retrofitted tip buttons) from 01032 to 00012
The tranny takes anything that is
010X2 where X is 1,2,3 - I cannot however change the 1 to 0 , which would allow me to use the Tip buttons when in "D" and not just Tip Mode
Is there anyway to use VAGCOM to interogate the tranny as to why? Is there some setting in INSTRUMENTS (17) that needs to reflect this ???
Help
Full Scan Follows
VCDS Version: Beta 803.1
Data version: 20080108
Wednesday,12,March,2008,14:33:26:28032
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WA1YD64B93N001011
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 4Z7 907 551 S
Component: 2.7L V6/5VT G 0010
Coding: 07755
Shop #: WSC 78646
WA1YD64B93N001011 AUZ7Z0B2141391
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: 0000 1100
Address 02: Auto Trans Labels: 4Z7-927-156.lbl
Part No: 4Z7 927 156 M
Component: AG5 01V 2.7l5VT USA 2122
Coding: 01032
Shop #: WSC 02325
No fault code found.
Address 03: ABS Brakes Labels: None
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D55
Coding: 06397
Shop #: WSC 00000
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AD
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
Address 15: Airbags Labels: None
Part No: 4Z7 959 655 J
Component: Airbag 8.4EP 2000
Coding: 0000607
Shop #: WSC 02325 785 00200
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 H
Component: Lenkradelektronik D01
Coding: 01015
Shop #: WSC 12345
2 Faults Found:
01301 - Control Module for Voice Recognition (J507)
49-10 - No Communications - Intermittent
01304 - Radio
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 P
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 04264
Shop #: WSC 19411
2 Faults Found:
01303 - Telephone Transceiver (R36)
01304 - Radio
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 E
Component: - 2C1A1 D040
Coding: 25500
Shop #: WSC 09999
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15917
Shop #: WSC 01029
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0102
Coding: 00001
Shop #: WSC 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 4B0 035 192 P HW: 4B0 035 192 P
Component: RNS-E US3 H54 0200
Revision: 08S Serial number: AUZBZ7E0500156
Coding: 0519636
Shop #: WSC 00000 781 01234
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D07
Coding: 00030
Shop #: WSC 02325
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0519636
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01186
Shop #: WSC 00000
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 R HW: 8P0 862 335 L
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005043205
Coding: 0010877
Shop #: WSC 00000 000 00000
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 15
Reset counter: 223
End ---------------------------------------------------------------------
Help
Full Scan Follows
76 77
Coding: 07755
Shop #: WSC 78646
1 Fault Found:
Coding: 01032
Shop #: WSC 02325
Coding: 06397
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 02325
Coding: 0000607
Coding: 01015
Shop #: WSC 12345
2 Faults Found:
01304 - Radio
Coding: 04264
Shop #: WSC 19411
2 Faults Found:
01304 - Radio
Coding: 25500
Shop #: WSC 09999
1 Fault Found:
Coding: 15917
Shop #: WSC 01029
Coding: 00001
Shop #: WSC 00000
Coding: 0519636
Coding: 00030
Shop #: WSC 02325
Coding: 0519636
Coding: 01186
Shop #: WSC 00000
Coding: 0010877
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 15
Reset counter: 223
Based on the original coding, the DSP seems to be switched off. However...
...DSP shouldn't have anything to do with tiptronic buttons/paddels. Take a look at the coding table and see yourself which options are plausible.<ul><li><a href="http://wiki.ross-tech.com/index.php/5-Speed_Automatic_Transmission_(01V)">http://wiki.ross-tech.com/index.php/5-Speed_Automatic_Transmission_(01V)</a</li></ul>
Re: Based on the original coding, the DSP seems to be switched off. However...
Theresias
The coding table you provided does not seem to go with what Ive seen.
0XY32 - the "Y" or old or new strategy field does not work on mine
Also - why can I get a 3 if you only list a 1 or 0 for the second from the right? 2 and 3 are also valid codes BTW.
I dont think that coding table is accurate for mine - this is what I have
Why is there a difference?
Codes for '02 allroad 2.7T Tiptronic with Drive and Sport modes, and Tip
steering wheel controls:
01002 = Stock coding; live steering wheel Tiptronic controls in Tip mode
only; new Tip strategy, DSP active.
00002 = Live steering wheel Tiptronic controls in D, S or Tip mode; new Tip
01012 = Live steering wheel Tiptronic controls in Tip mode only; new Tip
strategy, DSP inactive.
00012 = Live steering wheel Tiptronic controls in D, S or Tip mode; new Tip
01022 = Live steering wheel Tiptronic controls in Tip mode only; old Tip
00022 = Live steering wheel Tiptronic controls in D, S or Tip mode; old Tip
01032 = Live steering wheel Tiptronic controls in Tip mode only; old Tip
00032 = Live steering wheel Tiptronic controls in D, S or Tip mode; old Tip
If you find a more complete coding table, let us know - we haven't found one yet.
I have no explanation why your control module wouldn't take the value, sorry.
Permited coding values vary according to TCU PN and firmware/software versions.
Reflashing the controller with later software version may or may not effect the coding values accepted.
