Question on stopping the low water spray for window alarm on a 2000 A4
Any way to stop it...
I tried today, but it would not take the code...
Is this because it's a 2000, or is there a different way to do it...thanks...
My default code is 02244...1.8T Quattro USA model...
Also I would like to change the date format to the Canadian version...I tried 02344 and it did not change either...<ul><li><a href="https://forums.audiworld.com/a4/msgs/1597491.phtml">https://forums.audiworld.com/a4/msgs/1597491.phtml</a</li></ul>
Re: Question on stopping the low water spray for window alarm on a 2000 A4
Hey hey,
I have the same problem. If the warning doesn't go off when you fill the reservior, then you may have a bad sensor. I've tried a lot of codes, but had no luck. The code 02244 doesn't even match up with Ross Tech's, so I don't know if our codes are updated or what.
Oh my sensor is fine,it is just so annoying I want to disable it...
Yea the codes are weird...I wonder is anyone knows here how to help us out...
Pull wheel liner back. Jump the two wires going to the sensor.
Never see the light again I had to do this when I took my stock windshield tank off. So I wouldn't see the low fluid light.
jaime
jaime
for the date format...
... I've tried to recode a US spec instrument cluster to display the date/time as the Canadian cluster and the display has issues. Some of the segments get messed up. Don't know whats going on but I suspect the US cluster is US only cluster.
Kir
Kir
N'Syncro
33
02-16-2020 03:12 PM
stormchaser1967
New Member Welcome Area
09-01-2015 01:29 PM
