Question on VAG-COM concerning scan faults
Is there a way to determine at what mileage a fault first appeared for your vehicle? TIA!
- I have an '02 A4 Avant
- I using a HEX+CAN with VAG-COM Release 512.4-D
- Fault found as follows:
Address 08: Auto HVAC
Part No: 8E0 820 043 Q
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
41-10 - Blocked or No Voltage - Intermittent
Coding: 00000
Shop #: WSC 63351
1 Fault Found:
Some (not many) fault codes have Freeze Frame data associated with them:
Otherwise, no.<ul><li><a href="http://www.ross-tech.com/vag-com/tour/dtc_screen.html">http://www.ross-tech.com/vag-com/tour/dtc_screen.html</a</li></ul>
Andy
Andy
That module isn't new/smart enough
to have recorded any "freeze frame" data when the fault occurred. So no, there's no way to tell at what mileage the fault first appeared.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
chasA4
09-07-2006 10:49 AM
Alex (lil' is 300)
60
12-25-2004 11:58 AM
Dean_Audi
VAG-COM Discussion
08-12-2003 03:31 AM
