Recoding Auto Trans.
I found the following code on a 98 1.8T A4
18089 - Control Module Programming Not Finished
P1681 - 35-00 - -
I noticed that the Auto Trans. has a zero coding. Just wondering what login and what coding (or process) I need to use to see if I can help a fellow member to fix his problem. Thanks
P1681 - 35-00 - -
00000 is the correct coding for that trany.
Any functional problems with the tranny?
Is the TCU "chipped"?
-Uwe-
-Uwe-
http://www.Ross-Tech.com
I hope this is what you are looking for
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine
Part No: 8D0 907 557 N
Component: 1.8L R4/5VT MOTR AT D05
Coding: 06251
Shop #: WSC 03008
1 Fault Found:
P1681 - 35-00 - -
Readiness: 0110 0101
Address 02: Auto Trans
Part No: 8D0 927 156 T
Component: AG5 01V 1.8lR4T US D06
Coding: 00000
Shop #: WSC 03008
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes
Part No: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
No fault code found.
Address 08: Auto HVAC
Part No: 8L0 820 043 B
Component: A4 KLIMAVOLLAUTOMAT_D73
Coding: 04140
Shop #: WSC 03008
Address 01: Engine
Coding: 06251
Shop #: WSC 03008
1 Fault Found:
P1681 - 35-00 - -
Coding: 00000
Shop #: WSC 03008
1 Fault Found:
Coding: 04140
Shop #: WSC 03008
TCU is not chipped. At least that is what I was told
He says the tranny seems not shift well. As though it does not know when to shift or how to shift. He also has trouble going over 60km/h. The car was chipped 2 years ago and this problem only came up recently.
Yeah, clears up something.
Your first post was confusing. You mention tranny stuff and the 18089 code, so I figured you pulled that code from the tranny.
Is the motor chipped? :-)
-Uwe-
-Uwe-
JNormS4
06-04-2013 05:19 PM
S4incter
08-18-2008 06:39 PM
