VAG-COM Discussion
Sponsored by:
Sponsored by:
Still having problems coding module....
Old 01-19-2006, 06:23 AM
4Bidden's Avatar
Default Still having problems coding module....
Itchy Foot over at AZ and I have tried again to do this. We think we have the right codes but when we go to do the steering angle sensor calibration, we either get an error or we get a negative value in the 900 range which keeps increasing as you turn the wheel either way. Sometimes the VAG displays 0 degrees and doesn't change when you turn the wheel. Then when you turn the engine off and back on, the ABS module resets back to zero. I was told that this was because the steering calibration needs to be done correctly in order for the module coding to stick. Is this correct?
Audi just quoted me 600 bucks for a new sensor so i was hoping that since we do get a reading, even though it is incorrect, the sensor is okay but needs to be re-positioned. Is this assumption valid?
Does anyone else have any insight into this problem?
stlthx
04-15-2018 03:46 PM
Ritz
VAG-COM Discussion
12
05-28-2006 06:44 PM
4Bidden
11
01-19-2006 01:17 PM
4Bidden
Canadian Discussion
01-19-2006 12:29 PM
Quick Reply: Still having problems coding module....
