Rich or lean how do I tell....
Re: Rich or lean how do I tell....
Look in block 217. There you can see O2 voltage and EGT in C°. The voltage is between 1 and 0. 1v is the same as an A/F ratio of 14,7:1. With that you can calculate the other values. Do a full throttle run from 2000 to 6500rpm.
Block 032 will tell you long term fuel trim at idle & part throttle...
So you can get a sense of if the car is running generally rich or lean. At WOT it relies more on fuel maps and not O2 sensors.
-Dave Pramanik
-Dave Pramanik
Audi A8 Mass Air Flow Sensor - Used
Projekt 8E
09-28-2015 05:49 PM
