Ross-Tech / VAG-COM or the Schwaben VAG
#11
Oh!? Thank You! I had no idea!
Well, that makes it easier! hehe
Ok, so then I can ask You something about what one could be good for me..
I have only MAC's in my home, is any Ross-Tech usable with that?
And I have no shop, thu I want to be able to use it for different vehicles (Audi/VW)
So, what one do You think I "need", compare to price?
VCDS License with HEX-NET (WiFi/USB) Unlimited VINs (all VAG)?
VCDS License with HEX-USB+CAN Unlimted VIN (All VAG)?
VCDS License with Micro-CAN Unlimited VIN (most VW '05.5 to current)?
Thank You
Thank You
Since Ross-Tech only provides software for Windows, you would either need to install a Windows emulator on your Mac or buy a cheap PC laptop.
#12
Audiworld Premium Sponsor
That is no longer true. Ross-Tech now offers our HEX-NET interface that is compute platform independent. It works wireless by WiFi to any device with a web browser. As I don't want to get abused here, I will not link the product listing. Go to the Ross-Tech Shop pages and you will find the HEX-NET device. It will work on Macs, iPad, iPhones, and even crazy devices like watches and video game consoles. It does not require an app to be installed - just a web browser.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
#13
Yes I wondered about that when reading Your website, but with this one, is there any cable follows as the other Ross-Tech's?
Or is this totally wireless?
A plugin that sends to "my" laptop/phone/Kindle?
Is it cable too, from the car to something?
Thank You
#14
I like the wifi idea, but I would go with the Hex-USB+CAN. I personally feel more comfortable with a wired connection.
I'm a linux/mac guy. I thought about running an emulator and saw that solution when I got my car about 3 months ago. I have ran emulators before no problem. But for $30, I just went with dedicated laptop.
#15
WIFI
Ok, guys.. I got sold on the WIFI set!
Ordered one and now I waiting anxcious!
I hope that its not only works on my iPhone, but also on my MacBookPro..
Thanx again for Your inputs
#16
No reason it shouldn't work on your MB Pro so long as you can access the internet with a web browser.
#17
Ok, late but here I am again!!
I bought the Ross Tech WIFI and below is my latest scan..
I had all "computers" out TCU etc.. Tugged in all cables but no luck/changes..
New battery, had all grounds inspected and "sealed"/cleaned..
All of the car looks like brand new to be honest
But why my transmission problem??
It runs in only 2 and 3rd, not in 1 or 4 or D..
And Level system icon shines, traction control and ABS light..
Here is my latest scan:
VCDS Mobile 0.4222.0.4
Chassis Type:4B
Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No SW: 4Z7 907 551 K
Component: 2.7l V6/5VT G 0002
Coding: 06752
Shop #: WSC 02325 000
VCID: 4BD9F42F69A511B7E4E142-5184
Subsystem 1 - Part No SW: WAU-YP5-4B5-1N1
Component: 47181 AUZ7Z0A1798088
2 Faults Found:
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No SW: 4Z7 907 389
Component: ABS/ESP allrad D5702
Coding: 06397
Shop #: WSC 23320 000
VCID: 09550E27235943A7164D18-5184
1 Fault Found:
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4B0 959 760 C
Component: Sitzmemory R1 BF 0102
Coding: 00003
Shop #: WSC 00000 000
VCID: 2D1D9AB7F7713F87DAD58C-4B3C
No fault codes found.
Address 08: Auto HVAC Labels: 4B0-820-043-MY1.lbl
Part No SW: 4B0 820 043 AH
Component: A6-Klimavollautomat D65
Coding: 00160
VCID: 60833383F023A2EF21D35D-25A6
1 Fault Found:
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
30-10 - Open or Short to Plus - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No SW: 4Z7 959 655 C
Component: Airbag Front+Kopf 2002
Coding: 00407
VCID: 4FE1E03F9DBD2D97880916-51A8
1 Fault Found:
01213 - Belt Tensioner Igniter; Rear Middle (N198)
32-10 - Resistance Too High - Intermittent
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No SW: 4B0 907 487 L
Component: Lenkradelektronik D03
Coding: 00112
Shop #: WSC 65535 000
VCID: 352DB2D71F217747A20534-4FFC
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No SW: 4Z7 920 980 B
Component: C5-KOMBIINSTR. VDO D13
Coding: 02264
VCID: 43C9DC0F41F5D9F71CB19A-5184
1 Fault Found:
01315 - Transmission Control Module
49-00 - No Communications
Address 34: Level Control Labels: None
Part No SW: 4Z7
Component: - 2C1A1 X031
Coding: 25500
Shop #: WSC 09999 000
VCID: C5CD4217CFC167C7B2A504-5184
2 Faults Found:
01316 - ABS Control Module
79-00 - Please Check Fault Codes
01769 - Sensor for Vehicle Leveling; Front Right (G289)
57-00 - Electric Circuit Failure
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No SW: 4B0 962 258 J
Component: Central Lock/Alarm D34
Coding: 15885
VCID: 302383C3E043526FF1F36D-4EEA
4 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01560 - Passenger Door
59-00 - Can't Unlock
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4B0 959 760 B
Component: Sitzmemory R1 F 0101
Coding: 00001
VCID: 2C1B97B3CC6B368FCDAB99-4B3C
3 Faults Found:
01445 - Sensor for Driver Seat Fore/Aft (G227)
29-00 - Short to Ground
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
29-10 - Short to Ground - Intermittent
20-00 - Malfunction in Basic Setting
Address 37: Navigation Labels: 4B0-919-887-BNS3.lbl
Part No SW: 4B0 919 887 B
Component: Navigation BNO 0001
VCID: 322789CBEE4F607F87E757-4B1E
1 Fault Found:
65535 - Internal Control Module Memory Error
00-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No SW: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
VCID: 260F659BD2870CDF1B6FDB-5160
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No SW: 4Z7 907 357
Component: dynamische LWR D06
Coding: 00030
VCID: 044B1F13047B1ECF653B51-4B9A
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No SW: 4B0 035 195 A
Component: Radio D00
Coding: 00114
VCID: 1E7F4D7B8AD7D41F533F33-4B9A
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No SW: 8Z0 919 283
Component: Parkingsyst. A6 RDW D05
Coding: 01186
VCID: 0247190B1E6F10FF570767-5184
1 Fault Found:
01548 - Sensor for Parking Aid; Rear Right (G206)
31-00 - Open or Short to Ground
Chassis Type:4B
75 76 77
Coding: 06752
2 Faults Found:
Coding: 06397
1 Fault Found:
Coding: 00003
Coding: 00160
1 Fault Found:
Coding: 00407
1 Fault Found:
Coding: 00112
Coding: 02264
1 Fault Found:
Part No SW: 4Z7
Coding: 25500
2 Faults Found:
Coding: 15885
4 Faults Found:
35-00 - -
35-00 - -
Coding: 00001
3 Faults Found:
1 Fault Found:
00-00 - -
Coding: 00102
Coding: 00030
Coding: 00114
Coding: 01186
1 Fault Found:
#19
Unfortunately, the VCDS can only pinpoint and describe the faults but a Bentley repair manual would be helpful for troubleshooting and repair procedures.
#20
