VAG-COM Discussion
Sponsored by:
Sponsored by:
VCDS / Vagcom fault 03041 - Audi A4
Old 10-01-2011, 07:52 AM
headache5678's Avatar
Default VCDS / Vagcom fault 03041 - Audi A4
I got this fault code running the latest VCDS on my 2009 Audi A4(B8)today. Although I had not started the car for for 3 weeks until I drove to work on the morning of 26th September, there was no evident problem then i.e. turnover was not at all sluggish. Does this fault code indicate a battery that is likely to fail or something else ?
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0091
Revision: GB102039 Serial number: 3900G084288347
Coding: 000303
Shop #: WSC 06325 000 00000
VCID: 468946D6483C
Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
1 Fault Found:
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 130
Mileage: 55213 km
Time Indication: 0
Date: 2011.09.26
Time: 09:04:00
Old 10-01-2011, 08:56 AM
Audiworld Premium Sponsor
Uwe@Ross-Tech.com's Avatar
I doubt it. Look at the fault prority. It's 7. Look here. That's just about as low as you can get.
Given that the car was sitting for 3 weeks, I would clear this and not give it a second thought unless it comes back.
-Uwe-
http://www.Ross-Tech.com
davieboy
09-03-2018 11:17 AM
am_ver
04-14-2011 08:55 AM
S4_Cinci (I S'edTFA)
02-12-2007 12:01 PM
TCRAIG
08-18-2005 09:10 AM
SCarGo02
01-15-2004 07:43 PM
Quick Reply: VCDS / Vagcom fault 03041 - Audi A4
