S6 V8 2000 VCDS label file problem
Hi everyone,
I'm using VCDS lite and have a problem to understand all metadata from VCDS.
I get the redir fail message for the engine controller.
Anyone that know how to build your own lable file?
My controller is 4D0-907-558, its an Audi S6 2000 (AQJ engine)european model.
Or can I modify a similar label file and "fool" the VCDS to at least present some information?
By from Sweden
Hi everyone,
By from Sweden
Hi Sebastian,
this is the latest.
VCDS-Lite Version: Release 1.1
Monday, 12 September 2011, 13:29:48:55269
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,06,08,15,16,17,18,34,35,36,37,45,55,56,57 ,65,67,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 4D0 907 558
Component: 4.2L V8/5V G 0002
Coding: 05752
Shop #: WSC 02325
VCID: EAA7164E8571
1 Fault Found:
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.LBL
Controller: 4B0 927 156 BT
Component: AG5 01L 4.2l5V RdW 1314
Coding: 00001
Shop #: WSC 02325
VCID: 7A87A60E75D1
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Controller: 8D0 907 389 F
Component: ABS/ESP allrad D36
Coding: 06397
Shop #: WSC 02325
VCID: 361F723E0149
No fault code found.
Address 08: Auto HVAC Labels: 8D0-907-389.LBL
Controller: 4B0 820 043 L
Component: öA
VCID: 2339BB6AA2DB
Note: Excessive Comm Errors
Address 15: Airbags Labels: 4B0-959-655-AI7.LBL
Controller: 4B0 959 655 E
Component: Airbag Front+Kopf 0001
Coding: 00406
Shop #: WSC 02325
VCID: 32174E2EED21
Address 17: Instruments Labels: 4B0-920-xxx-17.LBL
Controller: 4B0 920 930 P
Component: C5-KOMBIINSTR. VDO D07
Coding: 17083
Shop #: WSC 40978
VCID: 2D2D5D52F41F
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0X1169542
Address 35: Centr. Locks Labels: 4B0-962-258.LBL
Controller: 4B0 962 258 E
Component: Zentralverrieg.,DWA D32
Coding: 04683
Shop #: WSC 02325
VCID: 2B29534ACA0B
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
Address 37: Navigation Labels: Redir Fail!
Controller: 4B0 035 192 E
Component: Navigation 0004
Coding: 00000
Shop #: WSC 02325
VCID: 1F31B79A8EB3
Address 45: Inter. Monitor Labels: None
Controller: 4B0 951 178 A
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 02325
VCID: 263FA27ED1E9
Address 55: Xenon Range Labels: 4B0-907-357-AUT.LBL
Controller: 4B0 907 357 B
Component: dynamische LWR D03
Coding: 00020
Shop #: WSC 02325
VCID: 2721AF7AD6E3
Address 56: Radio Labels: Redir Fail!
Component: Radio 0004
Coding: 00017
Shop #: WSC 02325
VCID: 1F31B79A8EB3
Address 76: Park Assist Labels: 4B0-919-283.LBL
Controller: 4B0 919 283 PF
Component: arkingsystem A6 RDW D18
Coding: 01116
Shop #: WSC 02325
VCID: 7C8BA0167FE5
End --------------------------------------------------------------------------------------------------
this is the latest.
Coding: 05752
Shop #: WSC 02325
VCID: EAA7164E8571
1 Fault Found:
Coding: 00001
Shop #: WSC 02325
VCID: 7A87A60E75D1
1 Fault Found:
Coding: 06397
Shop #: WSC 02325
VCID: 361F723E0149
Component: öA
VCID: 2339BB6AA2DB
Coding: 00406
Shop #: WSC 02325
VCID: 32174E2EED21
Coding: 17083
Shop #: WSC 40978
VCID: 2D2D5D52F41F
Coding: 04683
Shop #: WSC 02325
VCID: 2B29534ACA0B
2 Faults Found:
35-00 - -
00955 - Key 1
Coding: 00000
Shop #: WSC 02325
VCID: 1F31B79A8EB3
Coding: 00102
Shop #: WSC 02325
VCID: 263FA27ED1E9
Coding: 00020
Shop #: WSC 02325
VCID: 2721AF7AD6E3
Coding: 00017
Shop #: WSC 02325
VCID: 1F31B79A8EB3
Coding: 01116
Shop #: WSC 02325
VCID: 7C8BA0167FE5
Looks like we never made a label file for the AQJ engine. If you had a full version of VCDS, we'd ask you to send maps, but VCDS-Lite doesn't have that function.
Since the AQJ engine was used in model year 2000-2002 Euro A6's only, it's a pretty rare specimen. However, it should fit this scheme reasonable well.
-Uwe-
-Uwe-
http://www.Ross-Tech.com
Thanks Uwe for looking in to this matter!
Just to be clear that I follow you,
I can upgrade my VCDS Lite to a full, send the data to you and you support me in building a functional label file for the AQJ motor?
Yes, that's correct, but we won't prmomise you a time-frame for getting a file like that done.
-Uwe-
-Uwe-
OK, that sounds interesting.
Also, trying to detect misfire but do not get any read-out on group 014 and upwards to 020.
Will that work with the full version of VCDS?
Greetings from Sweden
No, the actual data available will not change with the full version of VCDS vs. VCDS-Lite. This is determined by the car, not the software.
It is quite possible that your ECU doesn't support misfire detection; this was required for US emissions standards starting in 1996 but I don't think it was required in Europe (or Rest of World) yet in MY 2000.
-Uwe-
-Uwe-
happyuniverse
10-11-2012 05:58 AM
technics100
VAG-COM Discussion
03-24-2009 06:27 PM
srosie
04-06-2000 11:52 AM
