Soft Coding VS Long Coding
I have a 2007 Audi Q7 and am using a generic cable with VCDS 805.1. Everything seems to work fine, I can code what I want as long as it is the soft coding. I never get the option for long coding except for when I try to code the gateway, I see the long coding helper there.
Is this a by-product of using the generic cable with 805? I also tried VCDS-lite and have the same results.
Or is it that I just cant use long coding?
Audiworld Premium Sponsor
There is no such thing as a generic VCDS 805.1. You have an illegal clone copy of our VCDS product. VCDS-Lite will not work well with your Q7 if it works at all.
If you want and need full functions, visit Ross-Tech's website and buy the real VCDS.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
Question about your other comment. Is it that the cable won't work correctly with VCDS-Lite or is it that VCDS has specific functionality for a Q7 that VCDS-Lite does not?
VCDS-Lite appears to function with my cable but maybe that is why I don't get the long coding helper...and maybe why some coding doesn't remain after several hours.
Q7 is not supported by VCDS-Lite... you need a CAN based interface to speak the Q7. You need a full VCDS package to access coding in that car.
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
DPDISXR4Ti
12-27-2008 08:25 PM
A4AdMan
10
06-05-2008 06:00 PM
05whtaudia6
VAG-COM Discussion
12
05-13-2008 10:29 AM
