VAG-COM Discussion
Sponsored by:
Sponsored by:
2003 A4 Cabriolet Electrical Issue
Old 04-29-2014, 07:19 PM
HereInOhio's Avatar
Default 2003 A4 Cabriolet Electrical Issue
I
Old 04-30-2014, 04:08 AM
jakematic's Avatar
Originally Posted by HereInOhio
She had it jump started two times to move it. I installed a new battery and a lot of the electronics are not working
Using the proper procedure, at the jump points per the manual ?
If an Audi is improperly jump started a lot of modules can get fried.
Does the CAN gateway installed list match the modules in the vehicle?
May also want to do an optical diagnostic - that usually makes it easier to pinpoint bad modules.
Post up a complete scan and optical diag, maybe we can figure out more from there.
Old 05-03-2014, 05:54 AM
jakematic's Avatar
When you say CAN gateway list based on quick research I'm assuming you are talking about using VCDS to show what modules the car has.
Yes, there is an installation list on the gateway that shows which modules it thinks it has.
From there not sure how I would verify if the car has the modules without physically getting to each so I'm assuming you are saying just use common sense if it has them? Eg. if it says you have a door lock module but you have manual locks well somethings wrong?
Generally yes, but you can also reverse engineer the list based on the PR code (build) sticker - usually in the spare tire well, in the book sometimes, or other places.
The guy that had the "real" rosstech cable charged me to scan it but wasn't very through. I have VCDS light and a china cable that I picked up before knowing their was a difference and the advantages of getting the real deal cable. I'm now looking into which one I should get because my girlfriend and here mother have audi's and that's all they buy. Figure I better get to know these cars and the proper tools soon. I will see if VCDS light will allow me to do the optical scan, if not I will have to turn up my cable search on my priority list.
If you have someone scan it make sure to get a copy of the Auto-Scan text file, have them clear all DTC's, and go from there.
Some of the less expensive cables work with VCDS Lite but ultimately it's an exercise in frustration and/or they have very limited functionality.
If you have friends/family with or other VAG (non Porsche) vehicles these things pay for themselves.
I don't do much of my own work anymore, but Audi charges me $135/hr for diagnostics which adds up fast
A good factory repair manual such as Bentley or erWin is another great investment if you plan to do any DIY.
The HEX-USB+CAN is probably your best bet but don't hesitate to look over the application charts or talk to Ross-Tech, they are a great group of folks.
Sometimes you find them on eBay or on the classifieds here, but be very wary of 'cracked' or knockoff versions.
They also hold their value well, so don't expect to find one much under $300.
Looking at ross tech's site it looks like the CAN gateway started in 2008. Im curious if the optical scan started after 2003 as well. I looked at all areas and dont remember seeing it. I will post what ever I can obtain later.
This I'm not sure about...
My experience is mostly with the 2005+ C and D models.
More than happy to assist, no worries.
5 years ago I could barely spell Audi and thought VCDS might have been a European beer.
I'm just paying forward all the help and education I've received here on AudiWorld
Old 05-09-2014, 09:21 AM
jakematic's Avatar
Without a complete auto-scan it's hard to say what if any problems there are....
Old 05-10-2014, 04:24 AM
jakematic's Avatar
Ok. That due to not having a registered cable im assuming?
Correct.
If you want to go forward, my suggestion would be to get a full blown cable instead of registering the 'light' version.
Old 06-12-2014, 03:25 AM
HereInOhio's Avatar
Default Steering Angle Sensor
So I finally got around to scanning my car. After clearing the codes and scanning again it looks to be the steering angle sensor or the module associated with it. Do you think this would be releated to all of the rest of the problems I am experiencing with the interior electronics not working? I replaced the CCM to find out the old CCM was working. The CCM harness looked great with no splices or wires rubbed though.
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WAUAC48H23K027820 Mileage: 266640km/165682miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AF HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0003
Coding: 0016584
Shop #: WSC 00672 785 00200
VCID: 74E9D66C1490E0BE8FF-5178
1 Fault Found:
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No: 01J 927 156 FF
Component: V30 01J 1.8l5VT USA 3011
Coding: 00001
Shop #: WSC 04940
VCID: 75EFEB684FEAF9B6B81-515A
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 G
Component: ABS/ESP front 2328
Coding: 04279
Shop #: WSC 00672
VCID: 2C590E0CDC20F87E17F-513C
1 Fault Found:
18036 - Powertrain Data Bus
P1628 - 35-00 - Missing Message from Steering Angle Sensor
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00100
Shop #: WSC 00672
VCID: 2A550814D6D4E64EE53-515A
Address 15: Airbags Labels: 8H0-959-655-84.lbl
Part No: 8H0 959 655 B
Component: Airbag 8.4EC 1015
Coding: 0010105
VCID: 3977275873725DD69C9-5178
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8H0 920 950 E
Component: KOMBI+WEGFAHRS. RB4 D16
Coding: 02201
Shop #: WSC 03055
VCID: 2E5D0404EA3C8A6E39B-5178
WAUAC48H23K027820 AUZ6Z0C0062338
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00070
Shop #: WSC 00672
VCID: 040986AC1430D03EBFF-4B4A
Address 56: Radio Labels:
VCID: 55AF8BE8AC2A99B6981-4ECA
Note: Excessive Comm Errors
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F H11 X023
Coding: 00005
Shop #: WSC 00065
VCID: 356F2B680F6AB9B6781-4B32
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
49-00 - No Communications
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H11 X023
Coding: 00005
Shop #: WSC 00065
VCID: 356F2B680F6AB9B6781-4B18
1 Fault Found:
End ---------------------------------------------------------------------
Old 06-12-2014, 05:57 AM
jakematic's Avatar
I thought this sounded familiar - see my reply here: https://www.audiworld.com/forums/sho....php?t=2867392
mkaresh
A4 allroad (B8 Platform) Discussion
13
05-07-2016 02:21 PM
adminisTerTurbo
06-06-2006 10:53 AM
Patmsb
16
02-02-2004 10:28 PM
Quick Reply: 2003 A4 Cabriolet Electrical Issue
