VAG-COM Discussion
Sponsored by:
Sponsored by:
Torque (Torque Pro) OBD II phone app?
Old 01-14-2013, 09:33 AM
asp125's Avatar
Default Torque (Torque Pro) OBD II phone app?
Has anyone used the Torque Pro OBD-II phone app? If so what bluetooth VAG Com adaptor did you use with it? I've looked around and also on VWVortex and it seems some of the cheaper ones are hit or miss if it works with the VAG Com.
Old 01-14-2013, 06:04 PM
MetalMan's Avatar
Generally speaking Torque uses a generic OBDII reader, not necessarily something like VAG-COM.
A quick search revealed that a bluetooth OBDII reader won't work with the full version of VCDS (which requires a Ross Tech cable), and it may work with VCDS lite if you're good with drivers. But in any case Ross Tech doesn't support any bluetooth OBDII dongles.
So no, there isn't a bluetooth reader which will work for you (unless you personally can make it work).
Old 01-15-2013, 06:36 AM
jakematic's Avatar
VCDS Mobile is a project Ross-Tech is working on http://www.ross-tech.com/vcds-mobile/
Torque is a very interesting app, but as MetalMan said does not have the features of VCDS
If you have it, this interface works well
Amazon Amazon
It won't give you VCDS capability out of the box though, and might not even work with VCDS.
I have it and it works great with that interface but I've never tried it on our Audi's.
Old 01-15-2013, 07:27 AM
MetalMan's Avatar
I'm using that exact BAFX adapter for my car, 1998 Audi A4, with a Nexus 7 tablet I've integrated into the dash. It all works flawlessy.
Didn't know Ross-Tech was doing anything mobile-related... that's cool!
Old 01-15-2013, 09:39 AM
asp125's Avatar
I just want to read the codes. Too bad Ross Tech is only for PCs (Mac owner). Guess I'll wait for the mobile version or do like Metalman did.
Old 01-15-2013, 11:59 AM
jakematic's Avatar
Torque will read codes and reset MIL/CEL - did that on a Miata.
I am a Mac guy and run VCDS on it using Parallels.
Unfortunately I need Windoze for work so have an XP VM.
You can use it that way or with Boot Camp.
Ultimately VCDS Mobile will be the solution for everyone I think since it's browser based.
Old 09-03-2014, 07:03 AM
vicsvinyl's Avatar
Default Late reply
Bafk, nexus 7, 1999 a6 quattro.
All i get is throttle pos. and water temps. Oh and exhast codes I already knew. What am I doing Wrong?
Shouldn't the ecu have manufacturer an vin or do I need to fill those in manually/
Vic
Old 09-03-2014, 09:50 AM
jakematic's Avatar
Vic
I would suggest you ask the manufacturer of the software.
You might also ask in the model specific forum.
This works very nicely though
v6tdi
Q7 MK 1 Discussion
09-10-2008 06:22 PM
Jeff Vader - boscoj
05-15-2006 09:19 PM
Milpitas2.7T
20
09-25-2005 01:07 PM
boxster02
05-29-2005 04:39 PM
s4msp2
10
11-12-2003 06:00 PM
Quick Reply: Torque (Torque Pro) OBD II phone app?
