URGENT HELP NEEDED...03 ABS Module
While I use VC to perform an output test on 03 ABS MODULE, everything seem fine. After I completed the test, unplug the cable and end up 3 indicators flashing on the dash! Namely ((ABS)), ((!)) and the ESP triangular indicator...!Then I run a test on 03 and get the following DTCs
01044 Control module incorrectly coded
35-00--
00778 steering angle sensor (G85)
60-10-- Not matched intermiten
18256 Please check DTC memory of engine controller p1848 - 35-00--
While I tried to clear the DTC and scan again, I noticed the softcode as well as the WSC all become ZERO! And then I try to get a copy of the old scan and find that the original softcode is 04279 and the WSC is 06435. So I tried to code the control module by using the VC cable again.... BUT NOT sucessuful! after the job, I scan once again and the softcode and the WSC are both 00000... Please any big brother can help me out...PLEASE. Anything will do. Thanks once again.
35-00--
Not enough information, what car, M.Y. A4, A6, etc. ...
Before an ABS controller will accept recoding, a login code must be entered. Check the Ross-Tech Wiki for more infomation.
Why were you running output tests?<ul><li><a href="http://wiki.ross-tech.com/index.php/Main_Page">Here:</a></li></ul>
Kirk
Canadian Discussion
06-12-2004 08:26 PM
