VAG the "low fuel" light on the dash?
I did a search and didn't see anybody really talk about this, nor have I ever heard of anybody wanting to do this. But is there a way to VAG the 'low fuel' light that starts beeping at you when you have less than 40 calculated miles left to go on your tank? Or at least change the settings on it so it doesn't show your car being empty when the gas needle is still at a 1/4 tank (yes, I've let it go down to 'E' with the car beeping at me so I know I have a lot more fuel in reserve). Or is this just something that cannot be changed?
Not sure if this will help
In Instrument Cluster in Adaptation Channel 3, you have a Consumption Indicator field which is set to 100 as a default. You can vary the value between 85 to 115. That means +/-15% difference in the consumption.
iMMix
12
03-19-2008 07:41 AM
Jason_S
03-31-2001 01:20 PM
