Vag-Codes if anyone can help ...
Okay I pulled the following codes this morning;
Address 01: Engine
Part No: 4B0 907 551 K
Component: 2.7l V6/5VT G 0005
Coding: 06612
Shop #: WSC 02325
2 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC
Part No: 4B0 820 043 L
Component: A6-Klimavollautomat D64
Coding: 00160
Shop #: WSC 02325
1 Fault Found:
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks
Part No: 4B0 962 258 J
Component: Central Lock/Alarm D33
Coding: 15885
Shop #: WSC 02325
1 Fault Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
Sounds like a bad O2 sensor, not sure about the rest.
Thanks,
Aaron
Address 01: Engine
Coding: 06612
Shop #: WSC 02325
2 Faults Found:
Coding: 00160
Shop #: WSC 02325
1 Fault Found:
Coding: 15885
Shop #: WSC 02325
1 Fault Found:
35-00 - -
Thanks,
Aaron
Re: Vag-Codes if anyone can help ...
New lambda sensor, but check the wiring / plugs for corrosion and clean, clear codes see if the come back first.
HVAC right hand side temperature control is getting stuck, or rather the pot is loosing focus of where it is, worn, old, dirty internals in the pot, replacement... again could be connectors but if heating / ventilation is ok clear the codes & don't worry about it.
Alarm was triggered by the ultrasonic inside the car, could have been you left it with the window down or a flying insect got in and buzzed around a bit. Again as long as you don't have the alarm going of all the time just clear the codes.
Cool ..
The right side control for the temp is stuck, seems the previous owner spilled a drink at some point and the +/- buttons do get stuck on extremly warm days. Cool to see that the car monitors that LOL.
The alarm I figured was nothing, good to know that was correct.
The lambda I figured were the O2 sensors going out, since it should both specifically. I cleared the codes and I am waiting to see if they come back at all.
Thank you for the input and response to my initial post.
Aaron
Aaron
ar-Rings
Audi allroad
08-02-2008 09:25 AM
98Quattro
16
07-25-2008 04:20 PM
