Vag-Com Error Codes
Vag-Com Error Codes
So I just ran Vag-Com and had this error code:
2 Faults Found:
02558 - Left Rear Mid-Range/Woofer Loudspeaker (R159)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 144
Mileage: 88481 km
Time Indication: 0
Date: 2013.06.10
Time: 20:45:28
Freeze Frame:
Voltage: 12.20 V
Temperature: 32.0°C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 34.0°C
02559 - Right Rear Mid-Range/Woofer Loudspeaker (R160)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 144
Mileage: 88487 km
Time Indication: 0
Date: 2013.06.10
Time: 20:57:29
Freeze Frame:
Voltage: 12.20 V
Temperature: 39.0°C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 40.0°C
Do I need new drivers or new amps?
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 144
Mileage: 88481 km
Time Indication: 0
Date: 2013.06.10
Time: 20:45:28
Freeze Frame:
Voltage: 12.20 V
Temperature: 32.0°C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 34.0°C
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 144
Mileage: 88487 km
Time Indication: 0
Date: 2013.06.10
Time: 20:57:29
Freeze Frame:
Voltage: 12.20 V
Temperature: 39.0°C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 40.0°C
Audiworld Premium Sponsor
Are you having any real issue with the sound? An intermittent code means that at some point the code set but was not present at the time of the scan. It's something to watch but frankly, intermittent audio system codes are commonplace in VAG machines. My Tiguan throws them all the time and I have no issues with my sound system. So, I sometimes clear them and other times, I leave them so I can do demonstrations with the car to prospect users...
My read is, if you do not hear problems, you ain't got none!
-Bruce-
Ross-Tech, LLC
-Bruce-
Ross-Tech, LLC
Bobby Kinstle
VAG-COM Discussion
03-22-2005 09:17 PM
