VAG-COM what do I need - AudiWorld Forums
Old 07-26-2014, 06:17 AM   #1
Default VAG-COM what do I need
Hello. I fairly new to Audi and have got myself a 2004 A8. The car was left for 3weeks and looks like I had a bad battery as when I got back to it it was completely dead. Not even a LED. So new battery on and some of the features that I had before have gone. Eg the ability to be able to select the ride height. Just says that there is no further options when I press car and setup.
I have been told that using vag com I can get this back. What "bits" do I need I have seen the cables online. OBD to USB. What is the software?
Thanks
Ben
Foodboy is offline   Reply With Quote
Old 07-27-2014, 06:48 AM   #2
I have this same issues had to change battery now when i go to car set-up there is no option to raise or lower car, also no option for jack mode everything is gone, It was stated that you need vcds but after that how do you code to get those options back?
cdjocp is offline   Reply With Quote
Old 07-28-2014, 06:46 AM   #3
jakematic's Avatar
This is what you need: Ross-Tech Store: VCDS License with HEX-USB+CAN Unlimted VIN (All VAG)
I think it has to be enabled in the 'hidden' menu, but can't recall for certain.
The guys in the D3 forum would know for sure.
jakematic is offline   Reply With Quote
Old 07-28-2014, 07:04 AM   #4
Thanks for that. I will look into it. I was going to have a look a lowering the car slightly I have been told it is easy with the software.
Old 07-28-2014, 08:21 AM   #5
jakematic's Avatar
Yep, huge thread in the D3 forum on lowering with VCDS.
Thread Thread Starter Forum Replies Last Post
"Login lost due to dropped session" constantly cameltrophyallroad Audi allroad 4 02-14-2016 08:18 PM
Audi A6 FS: 2000 Audi A6 4.2 V8 Widebody - Bad Engine - Harrisburg, PA KevinLugnuts Vehicles For Sale 2 11-27-2015 05:43 AM
02 AR suspension help request dojo Audi allroad 3 09-28-2015 05:14 PM
VAG-com question (older serial port type) mxp A4 (B6 Platform) Discussion 0 09-28-2015 02:04 PM
Contemplating Buying a 2005.5 A4 Mikey319 A4 (B7 Platform) Discussion 3 09-12-2015 11:19 PM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
