VAG questions for S6...
"Turn off ignition before leaving car" warning, can this be disabled?
I tried the following and no success:
Disable Key warning (keyless models)
[46 – Central Conv.] [Coding - 07] -> Long Coding Helper -> Byte 9
Bit 7 set to 0 (Uncheck)
Also, I found the following for the Auto Release Brake without Seatbelt On. This will allow you to move your car and have the brake release without your seatbelt on. It specifies "Enter code presented by program." I tried the same decoder that is used for VIM and the security code produced does not work. Any idea which program is referenced here:
http://www.audienthusiasts.com/VagComPBrake.html
http://trick77.com/tools/mmi3g_vimcode.php#bottom
[53 - Parking Brake]
[Security Access - 16] (Enter code presented by program)
[Adaptation - 10] -> Channel 7 change 1 to 0
Jorge Vargas
09-08-2015 07:45 AM
