VAG-COM Discussion
Sponsored by:
Sponsored by:
VCDS Log with error codes. Thoughts?
Old 01-05-2016, 08:19 PM
Crai6m4ck's Avatar
Default VCDS Log with error codes. Thoughts?
I just bought a 2006 Audi A8L 3 weeks ago. I have fixed quite a few of the quick and minor fixes so now it's on to the more complicated stuff. Today I connected with VCDS, cleared all codes and then re-scanned. I am having trouble deciphering what the report says and I am looking for assistance.
Below is the log without all of the things that tested "OK" included, just the errors.
VCDS Version: Release 15.7.3 (x64) Running on Windows 10 x64
Data version: 20151216
Ross-Tech: Home
Tuesday,05,January,2016,13:53:16:61930
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number:
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E536E7AB9E6AF4ED3-807A
2 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 174328 km
Time Indication: 0
Freeze Frame:
RPM: 121 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 3.0°C
Temperature: 5.0°C
Voltage: 10.414 V
Readiness: 0110 1101
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number:
Coding: 0000000
Shop #: WSC 00000 000 00000
VCID: 326B7A0AADDE8BAEB7-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000011670
Subsystem 3 - Serial number: 0113.06.060000000100010096ÿ
Subsystem 4 - Serial number: 010096ÿ
2 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Mileage: 174328 km
Time Indication: 0
Date: 2015.12.26
Time: 02:10:58
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 15
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: 3663461A41B6978E9B-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150317
Shop #: WSC 02313
1 Fault Found:
00908 - Control Module for Wiper Motor
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 143
Mileage: 0 km
Time Indication: 0
Date: 2015.12.25
Time: 00:00:00
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 B HW: 4E0 035 593
Component: SDAR
Revision: 00000000 Serial number: AUZ4Z7E2018964
VCID: 2643965A9116E70E2B-8072
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 174328 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 075
Raw, Form. N/A: 000 000 000
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601150033
Coding: 0048702
VCID: 285F98629B02F17E19-807C
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
1 Fault Found:
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 103
Mileage: 131072 km
Time Indication: 0
Date: 2013.11.26
Time: 04:32:04
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 08902 444 56823
VCID: 204F8042F332093E51-8074
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 44
Time Indication: 0
Freeze Frame:
Voltage: 5.07 V
Count: 61
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396AU067531692
Coding: 0000002
VCID: 23458F4EE22412264C-8076
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 138
Mileage: 173699 km
Time Indication: 0
Date: 2015.12.22
Time: 21:47:18
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700037079
Coding: 0232125
Shop #: WSC 00000 785 00200
VCID: 5FCDC3BE8ECC76C628-800A
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 123
Mileage: 172698 km
Time Indication: 0
Date: 2015.12.12
Time: 15:35:05
Freeze Frame:
Speed: 0.0 km/h
Temperature: 14.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Old 01-05-2016, 10:18 PM
mishar's Avatar
Coding: 0007773
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Voltage: 0.000 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 174328 km
Time Indication: 0
Freeze Frame:
RPM: 121 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 3.0°C
Temperature: 5.0°C
Voltage: 10.414 V
Looks like low voltage fault was not cleared.
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 103
Mileage: 174328 km
Time Indication: 0
Date: 2015.12.26
Time: 02:10:58
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 15
Perform Coding and Calibration. Follow onscreen instructions.
Coding: 0143123
Coding: 00000035
Shop #: WSC 02313
Coding: 00150317
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 143
Mileage: 0 km
Time Indication: 0
Date: 2015.12.25
Time: 00:00:00
Probably just connection. If it works just forget it.
Component: SDAR
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 103
Mileage: 174328 km
Time Indication: 0
Freeze Frame:
Probably part of 07 fix. Check Installed List there.
Coding: 0048702
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 103
Mileage: 131072 km
Time Indication: 0
Date: 2013.11.26
Time: 04:32:04
Looks like your alarm horn is dead. It is on the right side just below windshield, under the plenum. Only way is new horn. Not cheap.
Revision: --H03---
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 44
Time Indication: 0
Freeze Frame:
Voltage: 5.07 V
Count: 61
Check the rear brake pads. They are either worn or somebody did poor job coding it when replaced. If they are physically OK perform VCDS procedure for replacement.
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 138
Mileage: 173699 km
Time Indication: 0
Date: 2015.12.22
Time: 21:47:18
Looks like antenna connection not perfect. If your radio is working just forget it.
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 123
Mileage: 172698 km
Time Indication: 0
Date: 2015.12.12
Time: 15:35:05
Freeze Frame:
Speed: 0.0 km/h
Temperature: 14.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Replace TPMS sensors. Buy aftermarket.
Old 01-06-2016, 06:17 PM
Crai6m4ck's Avatar
Mishar,
Thanks for all the help on all of the different topics i've inquired about so far.
Instead of "quote & reply" I took a different route to make it a bit easier to read.
Address 01: Engine
18010 - Power Supply Terminal 30 & 18061 - Please check DTC Memory of ABS Controller -
A moment before I ran the scan I selected the clear all codes option. I will clear again and rescan
00003 - Control Module & 01042 - Control Module; Not Coded - Perform Coding and Calibration.
I'll have to get to this tomorrow
00908 - Control Module for Wiper Motor -
It works and I will
02635 - Tuner Not Enabled/Activated -
Once again, I'll see what it says when I connect again tomorrow
01134 - Alarm Horn (H12) -
Least of my worries where I live
02596 - Rear Brake Pads Worn -
It must be the coding because my mechanic didn't mention it when he looked over the car before I purchased it 3 weeks ago and it just passed inspection. I'm unaware that there was any coding involved. Time for me to research this.
Address 56: Radio
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier -
Seems to be working just fine.
01521 - Sensor for Tire Pressure -
When I purchased the car the low pressure light was on. The dealer said he had purchased all 4 new TPMS sensors. Currently no low pressure light on. I'm a bit confused here.
A few weeks ago i found some decent tutorials on how to use VCDS specifically with a D3 A8 but I can't seem to find them now. Is there any consensus on a particular source?
ceroberts75
07-16-2016 09:20 AM
snatchman
08-28-2013 03:52 AM
khan98uk
VAG-COM Discussion
05-18-2013 02:01 PM
packge33
07-15-2012 12:17 PM
tashakes
VAG-COM Discussion
10-13-2011 06:51 PM
Quick Reply: VCDS Log with error codes. Thoughts?
