VAG-COM Discussion
Sponsored by:
Sponsored by:
VCDS / VagCom & MMI-3G+ Help...
Old 01-24-2015, 07:40 AM
AudiWorld Expert
iconoclast's Avatar
Default VCDS / VagCom & MMI-3G+ Help...
I need some help from anyone and everyone on here who is familiar with coding and the current MMI-3G+.
I asked the dealer to code windows down with my key fob and they accidentally disabled the seat memory function in the MMI. They have since tried everything to restore the functionality of the module but no luck. They had the car for over a month and even replaced the MMI module and still did not resolve the problem.
If someone on here has a 3.0T Prestige S-Line+ w/ Adaptive Suspension & B&O sound I need you to post for me your factory coding/codes and see if plugging those in would restore all the features otherwise I would need someone with extensive VCDS/VagCom knowledge to help me figure this one out on my own.
I contacted RossTech however since it was not done on my PC with my cable there is very little they could do for me. The changes were not stored in the adaptations log.
below you will find an image if the issue at hand:
Old 01-24-2015, 12:03 PM
GBW
GBW's Avatar
Maybe reach out to Boston Driver on the New England forum?
Old 01-24-2015, 12:26 PM
AudiWorld Expert
iconoclast's Avatar
thanks. i made a thread asking for assistance. hopefully he can help.
Old 01-29-2015, 04:42 PM
AudiWorld Expert
iconoclast's Avatar
Central Convenience is coded with 3438621.
Old 03-13-2015, 07:26 AM
AudiWorld Expert
iconoclast's Avatar
Resolution:
Technical Service Handbook (HST): 72 Seat memory does not work (2035357/1)
Technical Service Handbook (HST): 57 Remote key memory not active (2031413/2)
Refer to these two TSB which call for a software reload and should resolve the issue of a disabled MMI Memory Seat Control.
iconoclast
Q7 MK 1 Discussion
01-24-2015 09:58 AM
DeMOROlized
Canadian Discussion
01-15-2009 05:20 PM
nortonr
VAG-COM Discussion
04-21-2003 01:45 AM
MyKey
05-28-2002 03:41 PM
Quick Reply: VCDS / VagCom & MMI-3G+ Help...
