VAG-COM Discussion
Sponsored by:
Sponsored by:
What is cylinder voltage?
Old 07-12-2014, 04:52 PM
Audiworld Senior Member
ajg617's Avatar
Default What is cylinder voltage?
Anyone clue me in on what cylinder voltage measures on vag? I'm getting random misfires on cylinders 4 and 6. If I clear the codes, I get them right back on start up. Minimal misfire but I can feel it at idle or holding steady moderate throttle. Started watching cylinder voltage and misfires and that was showing cylinder 5 misfiring and the voltages were a bit lower on cylinders 1 and 6. 06 C6 3.2.
Thanks,
AJG
Old 07-13-2014, 06:17 AM
jakematic's Avatar
I think it is likely injector voltages.
Which group were you looking at and what DTCs are showing up ?
More info on measuring blocks http://www.ross-tech.com/vag-com/m_blocks/
Old 07-13-2014, 06:45 AM
ajg617's Avatar
P0304, P0306, and P0300. Groups 16, 26, and 27 (in the link, 26 and 27 fall under knock control so I'm assuming it is the knock sensor voltage).
Old 07-13-2014, 07:31 AM
jakematic's Avatar
Those are generic codes, so I generally don't bother to look them up.
More info here: http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
That was my other thought, and lacking coffee this morning, totally forgot to mention it
ajg617
07-12-2014 05:07 PM
maaliish
09-05-2006 02:18 PM
eldoj
08-29-2006 10:43 AM
fourwheelslide
9
03-12-2006 02:25 PM
PSmalls::DoggieStyle
13
10-17-2005 02:15 PM
Quick Reply: What is cylinder voltage?
