Go Back   AudiWorld Forums > AudiWorld Community > Vendor Showroom
Register Forgot Password?
Vendor Showroom A place where vendors may display their wares
Welcome to AudiWorld Forums!
Welcome to AudiWorld.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the AudiWorld Forums community today!
LinkBack Thread Tools Search this Thread Display Modes
Old 11-12-2013, 11:17 AM   #1
Audiworld Premium Sponsor
Account #: 146870
Default Blauparts: 10% Off G12+ Audi Coolant Antifreeze with Code NOV1113
Top 3 Reasons Why You Should Check Your Audi Coolant Antifreeze:
Pictured Example. Blauparts purchased a used 1997 Audi A4 with approximately 90,000 miles, which had 1 previous owner. The previous owner had every service record from the date of sale, regular oil changes, preventative maintenance, and took really good care of the car. However, note the sediment or contamination of the G12 coolant that was removed when we thoroughly flushed the system. Even when using approved coolant, years of continuous circulating through the engine causes a measure of sediment to buildup.
1. When was your coolant changed last? The combination of chemical additives contained in coolant (even long-life coolant), responsible for retaining alkalinity and inhibiting corrosion within the engine's cooling system, over time become depleted. Similar to oil, coolant eventually breaks down, becomes weak, and "gets dirty." For maximum corrosion protection and prolonged engine life, flushing Vw coolant every 3 to 4 years (40,000 – 50,000 miles) is important.
2. If your not the original owner, are you unsure what kind of coolant was used in the car? Have you, or the previous owner ever added coolant to the system that did not meet the G12 specification?
3. If your vehicle was manufactured before 2006 it was filled from the factory with normal (1st generation) G12 coolant. Timing belt replacement is a great opportunity to upgrade to improved G12+ coolant. Read what makes G12+ (plus) coolant better.
Note: If you can't confirm 100% that your coolant is not contaminated and free from contamination, do the new water pump, related components, and yourself a favor and thoroughly flush the system during timing belt replacement.
It has been noted that due to time constraints, inconvenience, and profit, many individuals, mechanics, and repair shops do not take the extra time needed to thoroughly flush the entire cooling system prior to the installation of a new Vw water pump. Just draining the cooling system and refilling it is not enough! Thoroughly flushing the coolant involves the engine block, radiator, heater core, and hoses. Cutting corners now adds time, labor, and money later. See our Coolant Draining Flushing Filling Service Bulletin.
Blauparts sells our BLAU® Timing Belt Replacement Kits with enough coolant to thoroughly flush / fill the cooling system. To ensure that your new timing belt components (especially your water pump) last, it's important to re-create the engine condition as it was when it left the factory, which means removing all contamination within the cooling system and engine block. See illustrations and example above.
Save on other Ravenol of Germany fluids with Code NOV1113
Audi Motor Oil
Audi Gear Oil / Differential Fluid
Audi Automatic Transmission Fluid
Audi Brake Fluid
Audi Power Steering / Hydraulic Fluid
Car Care Products
Check Out Our Other November Sales
Coupon Code NOV1113 for 10% Off All Ravenol of Germany Fluids
$5/$10/$20/$30 Off BLAU Valve Cover & Cam Chain Tensioner Gasket Replacement Kits
10% Off Valve Cover Gaskets
$15 Off BLAU® Timing Belt Replacement Kits
Website:
www.blauparts.com
* Free shipping offers are for FedEx Ground shipping to 48 US contiguous states only. Offers End 11/30/2013
Blauparts Sales is online now   Reply With Quote
AudiWorld
Audi R8
Paid Advertisement
Tags
audi antifreeze, audi coolant, blauparts, coolant, flushing audi antifreeze, flushing audi coolant, g12
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2014 AudiWorld.com Audi Enthusiast Community
