Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Mounting older Audi wheels (57.1 bore) on a newer Audi (66.6 Hub)
Old 09-23-2014, 04:35 PM
Sam Adams's Avatar
Default Mounting older Audi wheels (57.1 bore) on a newer Audi (66.6 Hub)
Hi
I am hoping to mount my old Audi wheels 5X112 (57.1 bore) on my 2012 A6 which uses as 66.6mm hub.
Does anyone know if it's even possible? Can I get Hub Centering rings?
thank you
Old 09-23-2014, 05:56 PM
mjfloyd1's Avatar
Originally Posted by Sam Adams
Hi I am hoping to mount my old Audi wheels 5X112 (57.1 bore) on my 2012 A6 which uses as 66.6mm hub. Does anyone know if it's even possible? Can I get Hub Centering rings? thank you
Machine shop could re bore them to 66.6 for you.
Old 09-24-2014, 04:23 AM
Former Vendor
Gary@Tirerack.com's Avatar
Hub rings would essentially shrink the wheel center bore down, not expand it.
Old 09-24-2014, 11:41 AM
Sam Adams's Avatar
Got it. mjfloyd1 you are correct I looks like the only way to mount these is to rebore them which I am debating now since there's no going back... mm thanks again.
Old 09-29-2014, 07:29 AM
mishar's Avatar
There is "going back". Just use hubcentric rings.
Old 09-29-2014, 08:07 AM
mjfloyd1's Avatar
There are rings that would do this. They would be 57.1mm inside and 66.6mm outside with the 5 x112 wheel bolt pattern. You can get specialty rings to do about anything -even change wheel bolt pattern. It would just be easier for me to have them re bored. But that's just me... I'm not sure how much the rings would run but they would need to be hub centric to avoid headaches
jared8783
09-09-2015 08:18 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
08-28-2015 08:50 AM
Rinmike
08-28-2015 12:19 AM
ECS Tuning-Audi
08-27-2015 12:42 PM
ECS Tuning-Audi
Audi allroad
08-27-2015 11:18 AM
Quick Reply: Mounting older Audi wheels (57.1 bore) on a newer Audi (66.6 Hub)
