need help with wheel spacer
Ok, so I got a newer set of wheels: ALY58851 Audi A6 10 spoke wheel, Bolt Pattern: 112mm Offset: 48mm Audi Part Number: 4F0601025CP with tires 245/40 r 18 Conti's.
My OEM wheel was ET43, with 235/40R18 tires.
I Installed one wheel on the front and it is rubbing.
My question is what wheel spacer size I need:
- 5 mm the difference of offset, or
-10 mm too make up for the wider tire?
thanks
thanks
AudiWorld Expert
I suspect that 5mm will work as it will push your offset to 48. You might post this on the A6 forum as there will be people there with experience.
thanks
thanks
baubau2.7
08-16-2014 09:22 PM
Hockenheim
Wheels & Tires Discussion
10
03-12-2014 10:03 AM
B6SilverS4
04-11-2006 08:51 AM
dolphizzle gray
11-10-2003 10:57 PM
