Rims
They bolt on. I know Mercedes used 66.6mm hub bore but I don't know if your Q5 is 66.6mm or 57.1mm hub bore. If your Q5 has 57.1 hub bore, I would recommend some hub centric rings so you don't feel vibration at higher speeds. Also recommend aluminum rings, they hold up better.
Now I think the ML runs a very high offset, you might have to run some spacers.
here would be an example: http://www.ebay.com/itm/Hubcentric-rings-66-6-OD-to-57-1-ID-Hub-Centric-Rings-4-Aluminum-Hub-Rings-/271711109561?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f433e81b9&vxp=mtr
Not expensive but will save you a lot of aggravation on trying to fix a vibration problem.
Blau Flash
9
04-11-2006 04:26 PM
villainS4
03-06-2004 05:18 PM
