Tires rub?
Need help finding the right tire size
I have a stock 09 a4 Quattro. I recently just purchased 18.8 wheels with a 35 offset. I'm trying to figure out the perfect size tire. the 245/40/18 looks to beefy. I was considering the 225/40/18 because it has the more sleek look with a little bit of stretch. Really am stuck between the 225/40 and the 235/40. I still want a sleek look but also some protection for my wheel. Any help would be greatly appreciated.
AudiWorld Expert
If you are worried about the look then go with a larger rim say 19" which will allow for a smaller aspect ratio.
If you go on the Tire Rack website and put in the info for your model car and wheel size it will tell you the alternate size tires you can use.
Unless the 18s I just bought grow an in over night I'm sticking with em, I'll go with the 235/40, and thank you very much for your advice, it's greatly appricated
are the toyo ts-1 suppose to look like off road tires cause my do. 235/40/18 have a bigger side wall
wasya152
20
05-28-2004 06:31 PM
MezulOwnsYou
06-03-2002 03:52 PM
CHUD
05-17-2002 09:31 AM
meem
10-09-2001 08:13 AM
