Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
'16 S3 35mm Offset IPW Wheels
Old 11-16-2016, 07:11 PM
GWMs3's Avatar
Default '16 S3 35mm Offset IPW Wheels
This is more of a public service announcement than a "please help me" post. Yes, I should have known better, especially for winter wheel setup. Just want to help someone avoid the problems I've run into. That is unless someone mounted tires to these wheels and had no issue
Purchased some IPW RS3 style wheels & winter tires for my '16 S3 w/19" wheel package. However I test fit and found an issue with clearance.
* Tires that were to be mounted 245/40 18 Blizzak WS80
Here are the stock wheel specs.
    IPW specs (Part # 628-FGMF1885.35-5X112)
      The vehicle is stock height with 10K on it. The issue is pictured below. Clearance looks to be less of an issue in the rear, but the front scares me.
      I'm currently looking for 8.5" wheels with a 45mm offset or 8" wheel w/ 35mm offset.
      If anyone has any advice, it would be greatly appreciated
      Old 11-16-2016, 09:59 PM
      TSHong's Avatar
      The fronts do look close. Depends if you can exchange the wheels for a different offset? Can you test fit a tire on the wheel and check?
      Old 11-17-2016, 07:43 PM
      GWMs3's Avatar
      I think I may have a tire mounted tomorrow and then update. I'be been looking at a million pictures of S3's with different wheels and it may not be as bad as first thought. I have had a number of different vehicles with plenty of wheel options and this is the first time I've been concerned.
      I will update with pictures as soon as I have a tire mounted Friday afternoon.
      Old 11-17-2016, 11:18 PM
      TSHong's Avatar
      Test fitting is the best way to go. I think it really depends on the profile of the specific tire. Good Luck. I think it will work out.
      Old 11-18-2016, 07:33 PM
      GWMs3's Avatar
      Well, I'm glad to say I'm surprised that they indeed do fit. Still not ideal in my opinion, but it is all in the tire profile as you pointed out. Which are a Blizzak WS80 245/40 18.
      Thank you for your words of encouragement, I appreciate it. I'll update with pictures when all are fitted to the vehicle.
      Old 11-20-2016, 11:07 AM
      GWMs3's Avatar
      Well, here's the finished product ...
      Old 11-20-2016, 04:05 PM
      TSHong's Avatar
      A lot of people like that aggressive look including myself. I'm glad it worked out for you.
      I'm here in ATL and I don't think I've sold a set more than 2 or three sets in over 25 years.
      Old 11-26-2016, 10:01 AM
      Former Vendor
      Doc@tirerack's Avatar
      ET35 is a little tight to the fender (obviously) and may rub if you bottom out the car on a big bump or pothole. We normally hover around ET45 for an 8.5" wide wheel. I'm sure you were given centering rings for the larger center bore (?)
      Old 12-11-2016, 04:09 PM
      GWMs3's Avatar
      Yup, I did get aluminum centering rings. I haven't had any rubbing issues thus far with just under 800 miles on the setup. I'll update if I have any issues down the road.
      DHS
      04-13-2019 05:12 AM
      Shawnm791
      11-14-2017 10:27 AM
      MontreAl
      Audi allroad
      11-23-2007 09:44 AM
      beav
      02-10-2004 02:15 AM
      max_2002
      12-31-2002 01:50 PM
      Quick Reply: '16 S3 35mm Offset IPW Wheels
