Wheels & Tires Discussion Discussion forum for all questions and topics regarding wheels and tires
Will these A4 wheels fit on my 2012 C7 A6?
Old 12-10-2013, 08:26 AM
Hockenheim's Avatar
Default Will these A4 wheels fit on my 2012 C7 A6?
Wheel Specifications
Size: 19" x 9"
Style: 5 Spoke
Lugs: 5
Bolt Pattern: 112mm
Offset: 33mm
Condition: Alloy Refinished
Part Number: 8T0071499
Notes: Accessory Wheel
Old 12-10-2013, 08:28 AM
Hockenheim's Avatar
Here is my stock size
Size: 19" x 8.5"
Style: 15 Spoke
Lugs: 5
Bolt Pattern: 112mm
Offset: 45mm
Part Number: 4G0601025E
Note: Option CU0
Old 12-10-2013, 02:03 PM
AudiWorld Expert
Reggie's Avatar
Doesn't the wheel mfr say if it will or not?
The offset is greater so that pushes the wheel out more and that means the added wheel width should be OK but the question now is if the wheel will hit the fender.
Nice looking wheel.
Old 12-11-2013, 09:19 AM
Hockenheim's Avatar
Nice looking wheel.
the wheel has a lesser offset than stock 33 vs stock 45, wouldn't that mean it would stick out less?
Old 12-15-2013, 12:19 PM
AudiWorld Expert
Reggie's Avatar
http://www.worldoneperformance.com/b...-offsets-work/
Old 12-16-2013, 01:15 PM
TSHong's Avatar
I think they will fit, but only true way would be test fitting them. The extra offset will bring the wheels out further. They will look aggressive on your car. If that is what you are looking for, go for it.
Old 12-18-2013, 09:27 AM
Hockenheim's Avatar
So being an expert, its impossible for you to answer the question?
Old 12-19-2013, 12:39 PM
TSHong's Avatar
I would say you have about 95% chance that they would fit. This is my opinion but I've been in the tire business since 1985. Now I'm showing my age.
Old 12-23-2013, 04:43 PM
Vijay's Avatar
Size: 19" x 8.5"
Style: 15 Spoke
Lugs: 5
Bolt Pattern: 112mm
Offset: 45mm
Note: Option CU0
They will fit. The wheel face will sit 18mm closer to the fender edge. This about the max that I would go. I assume you will be running a 255/40/19 tire and that will work nicely.
Old 12-30-2013, 09:00 AM
Hockenheim's Avatar
Stock tires should be ok right? Thanks for your expertise guys!
Quick Reply: Will these A4 wheels fit on my 2012 C7 A6?
