Will these fit 01 allroad?
Trying to build a winter set, steelees with taller rubber
225/70R16 +
Size 16" x 6"
Diameter 16"
Width 6"
Lugs 5
Bolt Pattern 112mm
Offset 40mm
Style 15 Hole
Audi Allroad 2001 16" Wheel Rim 58715
Thanks
225/70R16 +
Size 16" x 6"
Diameter 16"
Width 6"
Lugs 5
Bolt Pattern 112mm
Offset 40mm
Style 15 Hole
Thanks
Tire is 6.4% taller than OE, so I'd be concerned that you may rub over big bumps. Wheel offset is higher than we use for an AllRoad; needs to be around ET20. I guess if the vendor guarantees fitment (and will give you a full refund if they don't work), I'd recommend using 215/65R16 to stay close to OE tire diameter.
These would be closer but more cash. Cutting down on height slightly would be fine also. Thanks
Brand Factory OEM
Material Aluminum
Size 16" x 6.5"
Diameter 16"
Width 6.5"
Lugs 5
Bolt Pattern 112mm
Offset 16mm
Style 5 Spoke
Audi Allroad Quattro 2001 16" Wheel Rim 58741
Brand Factory OEM
Material Aluminum
Size 16" x 6.5"
Diameter 16"
Width 6.5"
Lugs 5
Bolt Pattern 112mm
Offset 16mm
Style 5 Spoke
Link20vt
Audi allroad
01-17-2005 03:09 PM
brick22
Wheels & Tires Discussion
04-24-2003 10:50 AM
lskolnick
Audi Original "S" Cars
04-04-2003 02:22 PM
