Wrenching question
Guest
Posts: n/a
Torque 'em on the ground
You have to torque the wheels on the ground since it's otherwise kinda hard to keep them from turning. :-)<p>Just loosen the bolts a little and re-tighten with a torque wrench in sequence, following the recommended "star" pattern.<p>(Check out this link to the Tire Rack tech info: http://www.tirerack.com/wheels/tech/torque.htm if you're unsure what I mean.)<p>Or, you could just wait until your next service and ask them how they properly torque the wheels.<p>HTH,<br>Jim
Guest
Posts: n/a
Actually, I read somewhere...
...80-90 ft/lbs for 14mm bolts (since the torque is based on the bolt/nut and not the type of wheels). It was a list of different size lug bolts/nuts and their appropriate torque range; may have been on Tirerack or Discount Tire website. If I find it, I'll post the link.<p>CraigB
Guest
Posts: n/a
Here's the torque info link...
My mistake, 14mm uses 85-90 ft/lbs. Of course, this link also says to go by the manufacturer's recommended torque, which is probably 80 (I was just too lazy to look it up; I found 90 in the archives). HTH.<p>CraigB<ul><li><a href="http://www.tirerack.com/wheels/tech/torque.htm">Tirerack Torque Tutor</a></li></ul>
GeoS4V8
Wheels & Tires Discussion
16
11-03-2021 03:52 PM
Reggie
RS4 (B7 Platform) Discussion
9
11-15-2007 02:21 AM
cdagza
06-04-2001 11:42 AM
