Tech Article Title Author Date
Floating Brake Caliper Service Grant Lenahan 2008
For those who want to work on their own (Audi) brakes, but don’t have a ton of experience, I thought I’d write this introduction and how-to directed specifically at the floating property of floating calipers. Get this right and your brakes work much better.
There are fundamentally two types of caliper designs. Fixed calipers and floating calipers.
Fixed calipers work as you might imagine all bakes work: a piston (or two, or three) on each side pushes its respective pad into the rotor. The caliper does not move. Fact is, these are rare. Floating calipers are a very clever simplification that saves cost and complexity. In a floating caliper, there is only one piston. The caliper itself floats on guide pins/rails, and physics helps us out: for each action there is an equal and opposite reaction. So as the piston pushes against the inner pad, the caliper gets pushed away, sliding inboard on its guide pines/rails, which pulls the outer pad against the outside of the rotor. If there were no friction, this would work perfectly.
Almost all Audi calipers are floating designs, unless you have an RS6 or RS4 or R8. And then we don’t feel sorry for you. So the following, based on a C4 (1995 a6q) illustrates the issues and the steps pretty well for most of our cars.
The picture below shows the front left caliper from a 1995 a6q partially removed. The caliper is attached to the caliper bracket / pad carrier by the guide pins themselves. The guide pins slide inside rubber bushings. In the picture below the guide pins have been unscrewed from the bracket, and the caliper partially pulled away. You can see the guide pins just to the right of the handle of the droplight.
As noted above, in a world without friction floating calipers would be great. If maintained, they work quite well. But over time, the guide pins get corroded and dirty; the grease is used up; and the rubber bushings get worn. All this means more play, more binding and more friction.
In this case, I cleaned the calipers, replaced and lubricated the guide pins and bushings, and re-installed nearly new pads (a pro had done the job less then 5k miles ago, but neglected all the niceties I’m writing up here). The result was smoother, more powerful and more progressive brake action.
The next picture shows the caliper lying on my bench. Note a few things. The old ratty brake line is just that – an old ratty brake line keeping dirt out of the caliper. Useful junk. Also note the two rubber bushings. These allow the caliper to slide on the pins. They also keep dirt out, sorta. There are plastic end caps. Finally, look at the caliper makeup. You can see the piston and visualize it pushing against the rotor, which pulls the other side TOWARD the other side of the rotor, applying the 2'nd pad.
The next photo is the same caliper, with a better view of the two rubber bushings. A guide pin replacement kit for this particular caliper costs about $20. It includes 4 guide pins and 4 bushing s, enough for both L & R calipers. The old ones pull out relatively easily. I first pushed the inside through, then took pliers and pulled the old bushing out by its dust collar (the outside part). The new ones just push in. I coated it with brake fluid first, so that it would slide in more easily. Brake fluid’s a fairly good lubricant and you have the assurance that it is compatible with the rubbers used and with your brake fluid. Duh.
You could also clean the old rubber bushings, although they will have worn / compressed. You can clean (alcohol and steel wool) the old guide pins too. In either case you need to grease them well with brake-part specific grease, usually moly based and very high temperature. And they have no petroleum distillates to attack the rubber.
At this point its reassembly time. There are good tutorials on pad/caliper assembly so I won’t go into it except to note three things:
1. The spring clip is a bear. Make sure you know exactly how it goes before you take it off. A pic is nice.
2. You want to bleed everything well. In fact, this is a good time to do your b-annual flush. Make sure you seat the pads BEFORE you open the bleeder nipple. Oh, and have a top quality 11mm flare nut line wrench for all this work
3. Make sure that the caliper truly floats now. It will be stiff, but should move a bit. No? Something’s wrong. In my opinion, this should be a part of any brake refresh. Pads alone are only half the job.
Enjoy, Grant
Terms of Use | Copyright © 1996-2009 by AudiWorld. All rights reserved.
