Angry at my AFC
Old 06-17-2013, 10:19 AM
Aspeed's Avatar
Default Angry at my AFC
So I installed new valves... Started it but it dies out 3 times in a row... Come to find out I forgot to plug in throttle body connector when I run the codes... Plug that in and she WONT F**KING START... Kept cranking it and all I seen was smoke lighlty rolling out of valve covers... Anyone can help it will be much appreciated... I NEED MY BABY BACK LoL
Old 06-18-2013, 08:44 AM
BFives's Avatar
Check to make sure your cam position sensor and crank sensor are correctly plugged in.
Old 07-09-2013, 03:10 AM
Bryans12v's Avatar
Did you try clanking the motor by hand first?
Old 08-09-2013, 06:19 PM
hubturn's Avatar
Double check the plug wires on drivers side. You may think they are on the correct plugs but that side is easy to screw up, because I've done it. It'll start, maybe, but run like crap.
Old 08-09-2013, 06:38 PM
Prospeeder's Avatar
Check for spark and fuel pump action. for some reason my 92 100cs after sitting awhile, wouldn't start, and the fuel line in the tank on the pump blew off somehow. i knew because i could hear the pump prime, then splash back down.
jurq
08-10-2007 11:13 AM
Snopyro
08-23-2005 09:02 PM
boxerfan
06-11-2005 06:29 PM
88OlympicEdition
11-22-2002 06:08 AM
Lutz
08-25-2002 10:22 AM
Quick Reply: Angry at my AFC
